postcardcv wrote in post #16001420
I use my 500 f4 on a tripod a lot and never turn the IS off, I don't have the issue of image drifting. I find that leaving the IS on helps to get sharp shots when shooting at really slow speeds.
If you are holding the camera (or have your hand on the camera), then yes, I would keep IS on. In that case you are likely still using SS greater than 1/15s or so, probably a lot more with a 500mm lens, even on a tripod, and IS will likely be useful. This is why most people with say they have not had a problem or noticed anything - most people won't with the typical use of a long lens, even on a tripod.
On the other hand, if you are hands-off, remote/timer etc.., with a SS less than 1/6s or so, then definitely turn IS off, although it may still be OK if you wait for it to settle down before tripping the shutter. I doubt many people shoot 'wildlife' lenses like that though. Honestly with a 300 2.8 or 500 f4 I can't imagine a situation on a tripod where I would switch IS off, because I can't imagine not having my hand on the camera. If the image moves around with IS on to the extent that it impedes your ability to put the focus point right where you want it, then I think something is wrong.
Of course I don't own a 500mm lens, but really the same applies for all IS lenses.
