Have a 430 II, looking for an off camera flash setup. Sometime to learn with for a while. Will the PW Plus III Transceiver (on 6D) work with Flex TT5 (mount flash on this). What else do I need? Why does the FlexTT5 get such bad reviews on Amazon?
DanFrank Senior Member 380 posts Likes: 3 Joined Dec 2010 Location: Buffalo, NY More info | Jun 06, 2013 17:59 | #1 Have a 430 II, looking for an off camera flash setup. Sometime to learn with for a while. Will the PW Plus III Transceiver (on 6D) work with Flex TT5 (mount flash on this). What else do I need? Why does the FlexTT5 get such bad reviews on Amazon? Gear "A creative man is motivated by the desire to achieve, not by the desire to beat others"
Whortleberry Goldmember 1,719 posts Likes: 53 Joined Dec 2011 Location: Yorkshire, England More info | Jun 06, 2013 18:12 | #2 DanFrank wrote in post #16006860 Have a 430 II, looking for an off camera flash setup. Sometime to learn with for a while. Will the PW Plus III Transceiver (on 6D) work with Flex TT5 (mount flash on this). What else do I need? Why does the FlexTT5 get such bad reviews on Amazon? Can't help you with PWs but in answer to your last question - I wouldn't take too much notice of Amazon reviews at all. There's no way of knowing the real level of expertise of the 'reviewer' other than that they can make a keyboard 'sort of' work (but they can't use spel-chequers :rolleyes Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
Jun 06, 2013 20:27 | #3 DanFrank wrote in post #16006860 Have a 430 II, looking for an off camera flash setup. Sometime to learn with for a while. Will the PW Plus III Transceiver (on 6D) work with Flex TT5 (mount flash on this). What else do I need? Why does the FlexTT5 get such bad reviews on Amazon? The PW triggers should play well with each other for the most part. There is a bit of kludging involved since youll have to open up the PW utility, hook up the triggers to your computer with the utility, update the triggers, and make the adjustments as needed. This to me is one of the big downsides to these triggers: having to go into software to make adjustments, test, make adjustments, test, etc... versus getting more basic dumb triggers that just tell the flash to flash (which, you can do with your setup, but again, you have to go into the utility to make the needed adjustments). http://imagedphotography.com
windpig Chopped liver More info | Jun 06, 2013 21:57 | #4 Get a set of YN622Cs. Would you like to buy a vowel?
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jun 07, 2013 07:25 | #5 DanFrank wrote in post #16006860 Will the PW Plus III Transceiver (on 6D) work with Flex TT5 (mount flash on this). Yes, the Plus II will be able to trigger a flash mounted on a FlexTT5. However, the FlexTT5 will need to be set to receive on the Standard Channel (default is to receive on the ControlTL channel) since that's what the Plus II transmits on. And, of course, there will be no ControlTL functions, such as adjusting flash power level, Hypersync, HSS, etc. You'll need a FlexTT5 or a MiniTT1 on top of the camera to use those features. DanFrank wrote in post #16006860 What else do I need? Nothing else if all you want to do is to remotely trigger a flash. DanFrank wrote in post #16006860 Why does the FlexTT5 get such bad reviews on Amazon? No idea as I haven't read the reviews on Amazon. ...Leo
NYC2BGI Senior Member 846 posts Joined Feb 2005 Location: Brooklyn, NY USA More info | Jun 07, 2013 07:56 | #6 windpig wrote in post #16007408 Get a set of YN622Cs. I agree! Canon 5D3, 5D2, 40D
| Latest registered member is EBiffany 1387 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
