Thread started 06 Jun 2013 (Thursday) 21:18
Non-convert RAW images go under exposed when I load to LR
theantiquetiger
Gallery: 35 photos
Joined Sep 2011
Jun 06, 2013 21:18 |  #1
I see my images in Cannon Digital Photo Professional, they look good. If I don't convert to jpg, the RAW image darkens like it is under exposed and if I increase the exposure in LR, it looks bad.
If I convert and save from RAW to jpg and than load into LR, it is fine.
Any idea what I am doing wrong?
http://www.flickr.com/​photos/theantiquetiger​/ (external link)
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Jun 06, 2013 21:37 |  #2
Lightroom can't read you're in camera settings so it takes the raw file and applied it's own default settings to it when it renders the image.
DPP can read your in camera preferences and applies them to the raw image. The raw image in DPP should look like the in camera jpeg preview.
500px (external link)
1x (external link)
instagram (external link)
theantiquetiger
Gallery: 35 photos
Joined Sep 2011
Jun 06, 2013 21:49 |  #3
Scatterbrained wrote in post #16007360 (external link)
so convert to tiff before loading to LR?
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Jun 06, 2013 21:59 |  #4
Or just open in Lr and process it there. The power of Lr is as a raw processor. If you're going to use DPP for processing your raw images you might as well get PsE instead of Lr.
1x (external link)
PixelMagic
Jun 06, 2013 22:01 |  #5
Lightroom - like all other third-party raw converters - is designed to read only a limited subset of your in-camera settings; ISO, aperture, shutter speed, and White Balance. All other camera settings are ignored so if your raw files are appearing darker in Lightroom it means that you probably have a setting like Auto Lighting Optimizer enabled in your camera.
theantiquetiger wrote in post #16007325 (external link)
theantiquetiger
Gallery: 35 photos
Joined Sep 2011
Jun 06, 2013 22:08 |  #6
PixelMagic wrote in post #16007416 (external link)
Lightroom - All other camera settings are ignored so if your raw files are appearing darker in Lightroom it means that you probably have a setting like Auto Lighting Optimizer enabled in your camera.
It only seems to do it with skin tones
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Jun 06, 2013 22:14 |  #7
theantiquetiger wrote in post #16007434 (external link)
Different picture styles effect color relationships. Landscape lends a blue bias for example. Lr can't read these styles, it takes the raw data and interprets it in it's own way, using the Adobe Standard as a default profile. The only image specific setting that Lr reads and renders is white balance. You can try using different camera profiles in Lr to see what works best, as well as trying a custom profile with a tool like the Color Checker Passport.
1x (external link)
hollis_f
Jun 07, 2013 07:24 |  #8
theantiquetiger wrote in post #16007390 (external link)
No. Create a set of default settings for LR that will more closely approximate what you require in the final image.
Find a representative image, not over or under-exposed, a decent range from blacks to whites, with a good selection of clours. Tweak the LR 'Basic', 'Detail' and 'Camera Calibration' settings in the 'Develop' module until the image looks its best. Then, still in the 'Develop' module, hold the 'Alt' key. You'll see the button in the bottom right change from 'Reset' to 'Set Default...'. Press that button and the settings you've chosen will be applied to every new image. There are options to have a different default for different cameras and ISO values - so you may have to do it a few times, or change those options in Edit | Preferences | Presets.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
IslandCrow
Jun 07, 2013 09:54 |  #9
hollis_f wrote in post #16008270 (external link)
That's similar to what I do. One of the really nice things about Lightroom is when I shoot raw (which is almost always), I could care less about picture style defaults in the camera, because I can create as many of my own in Lightroom as I want. For example, some of the presets I have are sports (daytime, nighttime and indoors), landscape, candid, street, various monochrome, and quite a few more. And I have those (or some subset) for my 5D, 40D and P&S cameras. When I import my raw files into Lightroom, I have it apply the appropriate preset, and now, depending on the picture, often all I have left to do is crop, possibly apply a white balance setting, and make a few minor tweaks.
So, I do understand why some people always use the Canon software for the initial RAW conversion, but for me, I consider the proprietary information that the Adobe software can't read is pretty insignificant.
tonylong
...winded
Gallery: 60 photos
Jun 07, 2013 18:46 |  #10
As a "reference" between DPP and Lightroom, it could be helpful to experiment with your Picture Styles (if you are working with Raw).
For example, I have my cameras set to the Neutral Picture Style (some prefer Faithful) and I have my Contrast and Saturation dialed all the way back to -4. So, this is what gets "viewed" in DPP when I open/view a Raw file. I find that these settings are fairly close to the Lightroom/Camera Raw defaults (the Adobe Standard profile). Using these settings can avoid the kind of confusion you are having, and of course you can change around the Picture Style settings in DPP as well as the camera profile settings in Lightroom.
Tony
snerd
Joined Nov 2010
Jun 19, 2013 02:20 |  #11
Thanks for this thread. When developing my new 7D raw files tonight, they looked underexposed and my black leather couch and loveseat had the purple fringe, and on my outside shots, any shadows were purple fringed too. Increasing the black level a couple of notches under Detail fixed it, then I saved it as Default. My first LR expedition!
tzalman
Fatal attraction.
Jun 19, 2013 02:46 |  #12
Detail is Sharpening (Amount, Radius, Detail, Mask) and Noise Reduction (Luminance: Amount, Detail, Contrast and Color: Amount, Detail). Nothing there to do with black point.
And if you saved the settings as a new default, you should keep in mind that any default is only a starting point and other images may need other settings.
Addendum: For purple fringing there are tools in the Lens Correction section; CA Removal and Fringe Removal.
Elie / אלי
snerd
Joined Nov 2010
Jun 19, 2013 08:36 |  #13
tzalman wrote in post #16044401 (external link)
.............. I have a black......... of course I'm a complete newb to this. Ver 5.
ETA: Oop's. It's under Basic.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/06/3/LQ_653332.jpg
Image hosted by forum (653332) © snerd [SHARE LINK]
boerewors
Joined Sep 2009
Jun 19, 2013 08:44 |  #14
for some weird reason the CA removal does nothing on my images. The fringe removal tool however does a fantastic job.
The most important piece of gear you own, resides in your head and its called your brain.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jun 19, 2013 22:29 |  #15
boerewors wrote in post #16044849 (external link)
Do you actually have any CA on your images prior to using it?
Dan Marchant
2,096 views & 0 likes for this thread, 10 members have posted to it.
1668 guests, 135 members online
