Thread started 07 Jun 2013 (Friday) 07:03
Depth of field at wide apertures
alann
Jun 07, 2013 07:03 |  #1
I see a lot of questions/complaints about lenses between 1.2 and 1.6 having focus issues. Many responses are "it is because of the DOF at that aperture" or something along those lines. To (hopefully) clarify how delicate it can be this for those new to this I have posted a crop showing DOF at 1.2. Look at the distance between the left eye (in focus) and the right eye. If either one of us had moved just a tiny bit the photo would have "focus issues". If you are new to wide apertures give yourself time to lean the lens. Don't get frustrated; these lenses must be tamed. I hope this post will help someone out there really understand shallow DOF with a wide aperture lens.
My FLickrPage (external link)
gasrocks
Jun 07, 2013 07:07 |  #2
I think you got the nose and neither eye. "Wide" apertures is not a term I know.
Goodysgotacuda
Joined Nov 2011
Jun 07, 2013 07:10 |  #3
I'm associating "wide" as in "wide open" = most light = low f#
Canon + 18-55mm f/3.5-5.6 IS kit | 55mm-250mm f/4-5.6 IS, 50mm f/1.8 | 10-22mm EFS
alann
Jun 07, 2013 07:11 |  #4
Yup^^^^ Thanks for making that more clear. :)
gjl711
According to the lazy TF, My flatulence rates
Jun 07, 2013 07:46 |  #5
This test is a bit misleading as it's showing the DOF at MFD or very close to it. DOF is not just a matter of aperture, that's one component but there are others to take into consideration. In this case the DOF if thin partly due to the the aperture at f/1.2 but partly due to you being a foot or 2 away from the subject. Move back to 5 or 10 feet an do the same test and both eyes should be well within the acceptable DOF range.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Tommy1957
Joined Apr 2013
Jun 07, 2013 11:23 |  #6
It is not difficult to get millimeter DOF with long focal length plus close subject distance plus wide aperture. Play with this DOF calculator; it is informative.
http://www.dofmaster.c​om/dofjs.html (external link)
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Jun 07, 2013 12:22 |  #7
gjl711 wrote in post #16008303 (external link)
True, but his example wasn't necessarily at MFD either, he stated pretty clearly that the image was cropped.
alann wrote in post #16008236 (external link)
I think this is a good bit of advice to people new to wide aperture lenses. When I first started shooting at 1.7 with my Yashica DS-M I thought something might have been wrong with the lens. Then when I shot using LV and 10x zoom I realized the lens was actually very sharp, just very hard to get a spot on focus using my T2i. Thankfully that's no longer an issue with the 6D and EG-S screen :)
Fuji X-Pro2 // Fuji X-H1 // Fuji X-T1 // Fuji X-100T
flickr (external link) // Instagram (external link)www.LucasGPhoto.com (external link)
alann
Jun 07, 2013 12:45 |  #8
It was not my intention to cause a ruckus. :) Just thought that it might help someone understand that these apertures are difficult and don't expect to put on the lens for the first time and get really good results. It just seems that many people are buying these lenses and posting how they have focus issues without realizing there is a learning curve (which I am still in) Here is the un cropped photo
IMAGE: http://farm9.staticflickr.com/8408/8978887279_24cd568534_b.jpg
IMAGE LINK: http://www.flickr.com …s/northphotos/8​978887279/  (external link)
watt100
Jun 07, 2013 13:39 |  #9
alann wrote in post #16009154 (external link)
We understand. You just wanted to show off your 85 1.2 L on a rainy day
well played
alann
Jun 07, 2013 13:54 |  #10
watt100 wrote in post #16009342 (external link)
well played
No sir. I am sorry I tried to help the newer photographers on this site. :( Not to worry guys it won't happen again. Let the bashing begin.
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Jun 07, 2013 15:02 |  #11
alann wrote in post #16009387 (external link)
Nonsense! I think it'll definitely be helpful to people learning the ropes, I fully get what you were trying to do. I think this forum could benefit greatly from a number of stickies at the top of the page with simple stuff like this. There's so much to learn with photography that when you're new at it it can certainly be overwhelming and all too often it's just easier to blame your gear (even when you shouldn't).
Tommy1957
Joined Apr 2013
Jun 07, 2013 15:15 |  #12
Hey! Please don't quit. I've been doing this for 40 years, but I am always open to new stuff. I struggle with f/2.8 sometimes. I can't imagine making f/1.2 or f/1.4 work for me. A little teasing never hurt anyone. All you did was provide information, which is never a bad thing. Some folks need it or can use it, some folks don't. Simple as that.
frugivore
Gallery: 11 photos
Jun 07, 2013 15:29 |  #13
Like many beginning photographers, I would shoot my fast primes wide open when I first upgraded from the 18-55mm. With f/1.4 shooting half body portraits on a crop sensor, it worked fine. But when I moved to a larger sensor, I really had trouble getting both eyes in focus. Eventually, I decided that I much prefer that a subject's entire head is in acceptable focus and so began using f/1.4 only for full body shots. For tighter shots, I'll go to f/2.8 or even up to f/5.6 for headshots.
scottsoutter
Joined Apr 2013
Jun 07, 2013 16:35 |  #14
I agree about needing to tame the lens.
I picked up a Minolta Rokkor-x 50mm f/1.2 and had it converted to Canon EF mount. So far, I am mainly playing games with it, doing experimental shots to learn how it behaves, and generally faffing around. I *may* take it out and really use it one of these days, but right now the chance of me getting a good shot wide open in a more relaxed shooting style is pretty low.
It's a beautiful lens, and for its age it is in *perfect* condition, but it ain't easy.
scottsoutter
Joined Apr 2013
Jun 07, 2013 16:35 |  #15
PS - thanks for posting the thread alann.
2,142 views & 0 likes for this thread
Latest registered member is karozenix
888 guests, 328 members online
