Thread started 07 Jun 2013 (Friday) 19:53
Lighting room for architectural shoot
supernova23
1 post
Joined Jun 2013
Jun 07, 2013 19:53 |  #1
Hi
I'm shooting several rooms for a Architectural shoot and I need several small and very portable lights to light dark spots in the room, especially table tops and beds etc. I don't want to carry heaps of gear. Any suggestions?
Wilt
Jun 09, 2013 09:22 |  #2
There are small AC or DC powered strobes available from sources like B&H
http://www.bhphotovide​o.com …C-DC/ci/1239/N/403629775​1 (external link)
davidmtml
Joined Jun 2012
Jun 09, 2013 12:28 |  #3
Speedlights? Indoors, you often don't even need radio triggers, just something with an optical slave mode.
dmward
Gallery: 29 photos
Jun 09, 2013 15:36 |  #4
I use speedlites. Work great. Takes some planning. Get compact stands so the legs can be tightly configured if necessary.
I've also done shoots without any additional light and used the floating point file capability in Lightroom.
I generally shoot a bracket then find the best exposure for windows and add light as required.
If these are larger rooms in a commercial building then larger lights may be the only solution.
Another option is compositing. Mike Kelley has some good videos floating around, illustrating how he does it outside. Works much the same way inside.
This was with 3 600EX-RTs bounced into the wall. I generally use ETTL and each 600EX-RT is in its own Gr so I can run FEC up or down as required.
MikeinDallas
Joined Jul 2011
Jun 10, 2013 09:22 as a reply to  @ dmward's post |  #5
I've had very good luck in many lighting situations using a tripod & 3 exposures (HDR).
Balances window & dark spots very nicely using PS layers & adjustment & masking. And/or use some HDR software. Used just for the exposure dynamic range, not necessarily the Tone Mapping.
http://www.michaeladki​nsphotography.com …mHQS/20/L/i-rnpmHQS-L.jpg (external link)
http://www.michaeladki​nsphotography.com …VhF9/17/L/i-WF2VhF9-L.jpg (external link)
http://www.michaeladki​nsphotography.com …VGvG/17/L/i-wJhVGvG-L.jpg (external link)
Regards
Mike in Dallas (external link)
5D/II, T2i, G11
EF 24-105 L; EF 70-300 f4-5.6L; EF 100 f2.8L, EF 85mm f1.8
richardhurst
Joined Nov 2011
Jun 10, 2013 10:08 |  #6
dmward wrote in post #16014566 (external link)
Brilliantly done
www.richardhurstphotog​raphy.co.uk (external link)
https://www.facebook.c​om …otography/25411​6831306074 (external link)
http://richardhurst.50​0px.com (external link)
dmward
Gallery: 29 photos
Jun 10, 2013 19:26 |  #7
richardhurst wrote in post #16016800 (external link)
Brilliantly done
Thanks.
Not an interior but here's one that's a bit more complicated. Kind of same approach Mike used but backwards.
IMAGE: http://www.dmwfotos.com/4web/twilight-650-web.jpg
984 views & 0 likes for this thread, 6 members have posted to it.
2250 guests, 128 members online
