Knowing the 5D3 SD performance is not as good, what is the optimal SD card one should use (just for the backup or emergency purpose).
I believe the Extreme III type of speed is a waste..
So at what speed 5D3 will max out on the SD interface..
Jun 08, 2013 17:50 | #1 Knowing the 5D3 SD performance is not as good, what is the optimal SD card one should use (just for the backup or emergency purpose).
1xSHOT Senior Member 357 posts Likes: 8 Joined Dec 2010 Location: DFW, TX More info | Jun 08, 2013 17:55 | #2 imho:
kin2son Goldmember 4,546 posts Likes: 3 Joined May 2011 Location: Sydney, Australia More info | Jun 08, 2013 17:56 | #3 Permanent banI can't remember the speed on top of my head, but SanDisk extreme is more than enough, so no need to go extreme pro. 5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
CyberDyneSystems Admin (type T-2000) More info | Jun 08, 2013 18:04 | #4 In the 5DIII the fastest CF cards will write @ 80.2MB/s GEAR LIST
EmaginePixel Goldmember 1,946 posts Likes: 43 Joined Sep 2008 Location: So Cal More info | Jun 08, 2013 18:06 | #5 Although 5D3 supports super fast UDM7 CF cards, it failed to do the same to its SD architecture. Therefore there's a bottleneck by using SD cards. I suspect it was put there to support video shooters who really do not need fastest card speeds. "Yesterday is history. Tomorrow is a mystery. Today is a gift. That’s why its called the present” - Kung Fu Panda
Jun 08, 2013 18:11 | #6 CyberDyneSystems wrote in post #16012380 In the 5DIII the fastest CF cards in that camera will write @ 80.2MB/s The fastest SD card will only write @ 19.9MB/s ie: 1/4 speed. This is what the OP is referring to when asking. -The Sandisk Extreme Pro 95 only gets 19.4MB/s -Where as the slower "normal" Extreme manages 19.3MB/s ( see a difference? not really ) - And a lowly Transcend UHS-1 18MB/s So no, don't waste your money on the fastest SD card for a 5D III ![]()
| Latest registered member is semonsters 1469 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
