FORUMS Photo Sharing & Visual Enjoyment Sports
Thread started 10 Jun 2013 (Monday) 04:35
Tennis - national level
RedCatPhoto
Joined Jun 2013
Jun 10, 2013 04:35 |  #1
Hello,
Interclub in my town, first time shooting with the 70-200mm f.2.8 IS ii USM.
Obvious issues with the shutter speed, shoud've shot more in shutter speed priority instead of Av. Also issues with composition.
1)
2)
3)
JM - facebook (external link) - website (external link) - gear list
Gatorboy
Jun 10, 2013 05:36 |  #2
Av is much more appropriate for sports than Tv -- unless you desire a slow shutter speed for panning.
Dave Hoffmann
RedCatPhoto
Joined Jun 2013
Jun 10, 2013 05:41 |  #3
Gatorboy wrote in post #16016152 (external link)
That's what I figured as well, but with a dark background (like in the third pic), it sets the shutter too slow to freeze the action properly. I guess I should set the ISO to auto to fix it.
Ralph ­ III
Jun 10, 2013 14:36 as a reply to  @ RedCatPhoto's post |  #4
AV and TV mode are inverse of each other in this case. So you can use either one to accomplish your goal. It often comes down to preference but I use TV mode significantly more in this case.
1) I shoot a lot of tennis tournaments and do so most often in TV mode. Because maintaining higher shutter speeds is the priority and I desire full control over that variable. I can tweak exposure as desired with ISO...
2) In theory, AV mode would seem best for such because it will always render the fastest Shutter Speed possible for a given shot. There are however many challenges and issues with that approach.
a) What if you desire a slower shutter speed for a particular shot in depicting motion?
b) What if it is a dark day (morning, evening, cloudy) or your subject is dark or in and out of shady areas? In that case you will not maintain a higher shutter speed as desired. This is the issue the OP experienced, btw.
c) What if you need a higher Aperture setting in getting two people (doubles players) in focus? Once more, your camera will adjust your shutter speed to a slower setting in accommodating for that, which may be slower than you desire.
AV mode is perfectly fine if the lighting is sufficient to maintain high shutter speeds and such is what you desire for a given shot.
3) If the lighting is really challenging or I need greater control, I will resort to full Manual.
You may get a lot of debate on this but this is what has worked best for me. I play and photograph a lot of amateur tournaments where there are often great challenges (tree's, backgrounds, daylight hours, clothing etc).
Again, it really is what works best for you OP but I would recommend using TV mode and set the ISO as needed. That scenario requires less adjusting btw as you really don't have to adjust the ISO much. Just set it to around ISO 500 (typical) and raise it as light diminishes or is poor (morning, evening, shaded). If I have to go over ISO 1000 due to poor lighting I will then resort to Manual mode or a faster lens.
You should also consider your metering mode OP. I most often use center weight but will resort to spot metering if needed.
Good luck,
Ralph
"SOUTHERN and SAVED!"
POTN FEEDBACK...............ITEMS FOR SALE
ktan7
Joined Mar 2013
Jun 10, 2013 14:51 |  #5
Good capture on these action shots :)
Vancouver wedding photography (external link)
Picture blog (external link)
Mexico wedding photographer (external link)
RedCatPhoto
Joined Jun 2013
Jun 11, 2013 02:26 |  #6
Thanks for the feedbacks ;)
Ralph, I'll try to shoot in Tv mode next time (especially if there are shadows and such). Surely the 5d mark iii would also be a better option than the 7d since it would handle higher ISO better if needed and reach is no factor when it comes to shooting tennis. And the FPS is still pretty decent for the matter I guess.
TheBrick3
Jun 15, 2013 11:42 as a reply to  @ RedCatPhoto's post |  #7
#2 is fun.
1D III 5D II 5D | 580 EX II x 2
17-40L | 35L | 100L | 70-200 II | 17-35 f/2.8-f/4
Website (external link)
John ­ Alberts
Jun 16, 2013 01:07 |  #8
like to see more
Met een Canon in je hand door de ganse wereld
1,338 views & 0 likes for this thread
Latest registered member is Jon1
919 guests, 291 members online
