After trying to wrangle an iPad into doing my bidding, it's just not worth it trying to pump any kind of RAW based workflow through it. It's an excellent viewer, but it can't do PP imho beyond tagging (I've tried a dozen apps!). I need a laptop to do PP on the road and improve my turn-around time.
Synopsis: Amateur photographer/videographer looking to pursue this as a hobby that eventually can at least pay for itself. I'm just learning what I don't know, and so the sky is the limit. I am skilled with computers and am a programmer at heart.
Current equipment:
- Canon 600D w/ ML
- EF-S 18–55mm f/3.5-5.6 IS II (kit lens)
- Buying: EF 50mm f/1.8 I/II
- 32GB SDHC (slightly too slow) + Buying: faster 32/64GB SDHC/SDXC
- Canon LP-E8 Battery + Generic LP-E8 Battery (both have been great!)
- Bad Targus Tripod Replacing
- Considering: a cheap camcorder that can be kept on a tripod. 1920p@60fps is ideal, but will settle for 1920p@30fps + 1280p@60fps
- iPhone 5: The ultimate in candid photography. Good for quick JPEG shots. Experimented with GPS logging for the 600D, but it's a pain and burns battery too quickly.
- iPad 4 (family's): Good for displaying a rough or finished product. Retina display and factory calibrated for sRGB out of the box. Not good for RAW or color-managed PP.
Usage: Raw photos primarily. JPEG when I need to be able to take continuous shots and am confident that my WB is fine. Panorama via JPG. Occasional movies (600D encodes high quality with poor compression, and needs to be trimmed on camera. It can easily be re-encoded by a more powerful computer to take advantage of advanced .h264 compression abilities with imperceptible loss in quality.)
Problem: My problem is PP. I used my home desktop, which is a gaming rig that was slowly converted into a workstation. It is straining for me to sit at a desk for that long. More importantly, I want rough drafts to show clients—ok, friends/family but I'm making a name for myself and am gaining experience and possibly gigs. I want faster turn-around times—faster Flickr upload after the event = more relevant. I also need to store all the data somewhere since I'm dumping my SD cards after the day is done.
Laptop:
Needs
- Good monitor. (1080p minimum resolution. IPS. Good gamut (sRGB as much as possible, decent factory calibration: will acquire colorimeter later. Fast refresh rate. 120Hz is a bonus but optional. High contrast, etc.))
- Optional: Retina-style display. This is expensive, so it can be sent to the chopping block!
- Linux-compatible.
- 13-14" is ideal, will consider 12-15.4" if needed.
- 64GB+ SSD disk.
- Optional: Additional internal HDD so I don't have to carry around an external HDD.
- Reasonable RAW processing.
- OpenCL video card. Also so I can play games.
- Multitouch trackpad.
- Internal DVD+/-RW.
- Internal SD/SDHC/SDXC card reader.
- HDMI external output
- 450Mbps b/g/n dual-band (2.4Ghz + 5Ghz).
- Optional: Touchscreen abilities of any kind.
Unneeded
- Raw power: Have my Frankenstein workstation at home.
- Large battery: Usually I can plug-in.
- OS.
- Software.
- Lightweight. I work out!
