Thread started 10 Jun 2013 (Monday) 12:50
soft shots?
Merlin_AZ
Jun 10, 2013 12:50 |  #1
I've recently graduated from the P&S world to a Canon SL1 with kit lens and 40mm pancake.
I bought the camera just before a recent trip, so I really didn't have a lot of time experimenting with it.
There was a link in another forum to print a sheet for lens focus testing, and on a tripod, to my eye, it looked fine.
In camera, my shots looked OK, using the center focus point only and recomposing.
When I got home this weekend, I was disappointed to see a lot of shots looking soft.
Some might have been my own fault using too large an aperture for indoor shots with flash, shortening the DOF with multiple people in the shots, but now I'm concerned that there is an issue with the camera/lens.
Is there something I can look at, or just send them to Canon and see what they say about calibration?
Thanks in advance.
maverick75
Joined May 2012
Jun 10, 2013 12:55 |  #2
It could be many things, such as the recomposing, shutter speed, etc...
Try shooting static objects, outdoors. Set it to single shot/single point. If it still has issues after that, it's probably the camera.
nekrosoft13
Gallery: 185 photos
Joined Jun 2010
Jun 10, 2013 12:58 |  #3
post some fullsize samples with EXIF intact (as links).
Mavgirl
Joined Mar 2013
Jun 10, 2013 13:01 as a reply to  @ maverick75's post |  #4
Focus and recompose combined with a shallow depth of field will often mean missed focus. But what you describe could be many things. I wouldn't send it in just yet. The first place to start is to post some images so people can give you ideas on what the cause might be. More than likely it's you. And don't feel bad about that if it is. When I first got my Rebel XT I had a lot of missed focus shots as I learned the AF system... and I was coming from a 35mm Rebel G with a similar AF system. Learning the ins and outs of the AF of a particular body is just like learning anything else in photography.
6D/50D/350D with too many lenses
Calumet 4x5, Pentax SV 35mm, Canon A-1, Rebel G and many more toys...
WaltA
Gallery: 10 photos
Joined Feb 2006
Jun 10, 2013 13:11 |  #5
What kind of post-processing are you doing? Most pictures out of the camera need some adjustments to contrast and some sharpening at the very least.
As was posted earlier, if you post a picture here as an example, it will be easier to give you some hints. "Soft shots" is a term that might be caused by many things. In particular an example picture will show whether its a focus issue, camera movement, DOF, subject movement or possible a lens problem.
Walt
400D, 5D, 7D and a bag of stuff
Merlin_AZ
Jun 10, 2013 13:14 |  #6
Thanks for the responses.
I'll try to post a few shots when I get a chance.
Another 2 points.
I shoot most of my shots in Av. When I first got the camera, shooting in Av indoors with the flash on slowed the shutter way down, and everything looked terrible. I checked the manual :) and there is a setting when shooting in Av with flash to force the shutter speed between 1/60th and 1/200th, with the warning that the backgrounds might look a little dark since there is less time for ambient light to get back to the sensor. Could that play a role?
I also turned off the AF assist light since it's the most annoying thing I've ever seen. The thing shoots out at least 2-3 very bright pulses before firing. I didn't think it would be an issue since it seemed to lock on very quickly without it. I'm assuming this could also be a culprit.
Walt, I pp in LR4.
sapearl
Gallery: 243 photos
Jun 10, 2013 13:21 |  #7
WaltA wrote in post #16017378 (external link)
As others have stated several factors can contribute to what "appears" to be a soft image.
If your indoor shots were done under low contrast lighting conditions where the quality of light was poor, even with flash, that could make your images appear less than sharp. Couple that with large apertures and shallow DOF and the affect would be magnified.
By your own statement it sounsd like you are just becoming familiar with the equipment and its controls. No disrepspect intended but it's more likely the cause of the apparent softness is your technique rather than equipment failure. I would not waste time with a repair call just yet.
Post samples with full exposure info and we can likely give you constructive clues.
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
sapearl
Gallery: 243 photos
Jun 10, 2013 13:24 |  #8
Merlin_AZ wrote in post #16017384 (external link)
Another 2 points.
Walt, I pp in LR4.
Yes, this could very well be the case.
In AV the camera could be selecting a shutter speed that is sufficiently slow for camera shake to be blurring the shots, motion blur on the part of the subject, or both. And this will be even worse if you are using low ISO settings.
Colin ­ Glover
Gallery: 17 photos
Joined Aug 2012
Jun 10, 2013 13:26 |  #9
Walt, I pp in LR4.
Absolutely. Are your soft shots mainly in low light situations?
Canon EOS 70D, Canon EOS 600D, EF-S 18-55 ii, EF 55-200 USM ii, EF-S 75-300 iii, Tamron 28-80, Sigma 70-210. Pentax 50mm, Pentax 135mm, EF-S 55-250, Raynox Macro adapter, Neewer filters (CPL, UV, FLD & ND4), Fuji HS20 EXR (30X zoom ) & cable release, Yongnuo 560 iii & Luxon 9800A manual flashguns for the Fuji, Hama Star 63 tripod, Hongdek RC-6 remote control, Velbon DF 40 www.point-n-shoot.co.uk website.
Mavgirl
Joined Mar 2013
Jun 10, 2013 14:34 |  #10
Another 2 points.
Walt, I pp in LR4.
On the flash... read up on second curtain sync. It might help you out there. And when shooting in AV mode you really have to watch that shutter speed.
Merlin_AZ
Jun 10, 2013 14:51 |  #11
Colin Glover wrote in post #16017422 (external link)
Probably over 85% were indoors with light that wasn't great.
I'll take some time tonight if I get a chance to look at some files side by side and compare typical indoor vs. outdoor shots and see how they compare.
Mavgirl wrote in post #16017673 (external link)
Thanks--I will read up on it.
My indoor shots with Av and flash were at least 1/60 since that was the setting I chose (#2 below).
There were 3 choices in the options:
1) camera control, which ended up way too slow to be useful
2) 1/60 - 1/200 (which is what I chose). Most shots ended up at 1/60
3) 1/200
I appreciate everyone's comments.
BrickR
Joined Mar 2011
Jun 10, 2013 15:43 |  #12
1/60 can introduce camera shake pretty easily if you're not being conscious about your hand-holding.
Most everything has been covered by the forum.
Congrats on the new camera! :)
My junk
The grass isn't greener on the other side, it's green where you water it.
sapearl
Gallery: 243 photos
Jun 10, 2013 18:05 |  #13
I admit to not using it very often myself, but how would second curtain sync.be used in this situation?
Btw Mavgirl, do you do any wet plate work with your Calumet? I've got a couple of friends who use field cameras and make their own exposure materials. It is truly quite an art ;).
ebann
Once an ugly duckling
Joined Jan 2003
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Jun 10, 2013 18:22 |  #14
indoor shots can be done like this:
Set to M mode, meter the background and UNDERexpose that background by 2-stops. Shutter speed can be as low as 1/30 but better to start at 1/60.
Use bounce flash from any wall/ceiling (but not direct flash) and leave it to A-TTL.
What happens is that you "under exposed" background won't affect the final output and it will not be too dark either. The flash will take of your subject and expose it perfectly, freezing the subject without camera shake.
This technique is very explained here:
http://neilvn.com …chniques/9-more-examples/ (external link)
Ellery Bann
Fuji X100
6D | Rokinon 14 2.8 | 50 1.4
1D Mk IV | 24-70 2.8L | 70-200 2.8L IS | 135 2L | 400 5.6L
1,625 views & 0 likes for this thread, 9 members have posted to it.
soft shots?
926 guests, 117 members online
