I've been reading around and I'm trying to understand the Ettl system and ratios.
From what I've gathered, group "A" is the master channel - the power is derived for this group, then B is set accordingly regardless of any other parameters (like distance)?
So if I have a subject and place a single group A flash at 2 feet 45 degrees camera left, and group B single flash at 2 feet 45 degrees camera right, and set my ratio 2:1 (B is half the power of A) and take a photo. And I leave all settings the same but move flash B to a distance of 4 feet, and take a shot, the image will look different correct? The resulting image will look as if I had set the ratio to 8:1 correct?
In addition, do the camera metering modes affect the ETTL exposure levels? For instance, if I have a black background and a relatively small white subject and I shoot with a single flash, at both Spot, and evaluative the resulting images will be different correct?
Finally - with the Pottix system, should the CAMERA flash setting be set to average or evaluative?
