When I first started shooting motorsports I was in the mentalitly of “I need to shoot everything in RAW to get the most I can out of every shot”. The problem though, is this lead to using a massive amount of card and hard drive space to store all of the images, and the I would always spend too long actually editing everything. I then discovered that you can make custom picture styles, and spent many many hours developing a custom picture style that would give me a Jpeg out of the camera that was very similar to how I would edit it from a raw. I used some older raw files, that contained problem areas that I encounter frequently (such as the horrible colour of green grass on a sunny day…) and tweaked and tweaked until I had something that worked with most all lighting situations.
Now I shoot JPG at every event, which forces me to think about what I’m doing a bit more, and not just thinking…I can just fix it later.
While at the track, I generally cull images on the go. Most of what I shoot is small races or time trial events, where each group is only on track for about 5 or so laps. Once they finish their session, while they file off and the next group file on, I flick back through the shots taken and delete anything that isn’t up to scratch. This saves a ton of time in lightroom later, as I don’t need to zoom in and check sharpness etc of each file, as I have already done this and know that any file that makes it to lightroom is of acceptable image quality.
Once back home, I put everything into a new lightroom catalogue, and apply my JPEG preset, which:
- Lifts the shadows a little
- Blackens the blacks a little
- Whitens the white a little
- Adds a bit of clarity
- Adds a bit of sharpness
- Adds a slight amount of vignetting
(all no more than about 10 points)
I then go through the shots from start to finish, cropping where required, and also adding slight grad filters to suit. Each picture that I like gets given a rating, then once through everything, it is sorted by rating, the shots I didn’t choose are removed, some keywords added and then exported and uploaded to the site.
With just this minor PP, this is the kind of look I end up with. Nice vibrant colours which is what seems to be popular and sought after for motorsport images, but without being over the top.
| Byte size: ZERO | Content warning: NOT AN IMAGE |
