Can anyone suggest the best way to micro adjust Canon lenses with a 5 D Mark III I did a search for it but there seems to be so many different suggestions. I really don"t want to spend 110 dollars for Fo Cal Plus. Thanks,
Alan
Jun 14, 2013 02:41 | #1 Can anyone suggest the best way to micro adjust Canon lenses with a 5 D Mark III I did a search for it but there seems to be so many different suggestions. I really don"t want to spend 110 dollars for Fo Cal Plus. Thanks, www.Marinelliphotography.com
Jun 14, 2013 04:26 | #3 Thank you www.Marinelliphotography.com
lovemyram4x4 Goldmember More info | Jun 14, 2013 12:48 | #4 Check out the dot tune method. It can also be automated using Magic Lantern.
Jun 14, 2013 13:47 | #5 I just did mine with a 50D and the Dot Tune method. It works really well and doesn't cost anything except time. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
pulsar123 Goldmember More info | Jun 14, 2013 13:49 | #6 +1 to dot-tune. Very fast and accurate. I don't think it is supported by Magic Lantern for 5D3 yet (perhaps only in their Nightly builds) - but I am sure it will. Under Magic Lantern, dot-tune calibrations is even faster and more accurate. 6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
tdodd Goldmember 3,733 posts Likes: 3 Joined Jun 2006 Location: Essex, UK More info | Jun 14, 2013 15:04 | #7 I love ML DotTune for my 5D2. Unfortunately it is not a camera I commonly use these days and I look forward to the day we get the feature on the 5D3. In fact, as a non video shooter I'd love a cut down version of ML that offered nothing other than DotTune as its only feature, especially if that would get it shipped out the door faster. It's by far the most useful feature of ML for me. If they could do ML-DT for the 1D3 - no idea if that's possible - I'd be thrilled. The other techniques, and I've used several, are quite the chore by comparison. Four bodies, around ten lenses and a couple of TCs are a lot of combinations of stuff to plough through when the weather changes or you begin to have calibration doubts.
agedbriar Goldmember 2,657 posts Likes: 398 Joined Jan 2007 Location: Slovenia More info | Jun 14, 2013 15:24 | #8 |
Jun 14, 2013 16:04 | #9 Magic Lantern has so many dire warnings associated with it that, even though I have downloaded it, I have not yet installed it on my 50D. I have, however, done Dot Tune manually and it is still easy, quick and accurate. Even with zooms on a camera with only 1 adjustment per lens, DT puts you right in the middle of the focus range of the lens. Just wanted to make sure no one thought you have to have ML to use Dot Tune. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
tdodd Goldmember 3,733 posts Likes: 3 Joined Jun 2006 Location: Essex, UK More info | Jun 14, 2013 16:18 | #10 I know the manual way is the original way, but compared to pressing a couple of buttons it's pretty tedious. FoCal has a similar feature as well, called TurbCal, but you need a PC/laptop to run that, wires all over the place and it's still a logistical exercise to put it all together.
Thank you every one for the great info! www.Marinelliphotography.com
pulsar123 Goldmember More info | Jun 14, 2013 22:01 | #12 Dot-tune under Magic Lantern is not just faster, but also more accurate. The reason is some lenses have their good MA interval going beyond the official MA range -20...+20. Without ML, dot-tune in such situation will compute wrong (skewed towards zero) result. ML has expanded MA ranges, like -40...+40, where no truncation will take place, hence median MA values will always be accurate. 6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
TeamSpeed 01010100 01010011 More info | Jun 14, 2013 22:36 | #13 I have a DIY freebie chart in my signature, or a very inexpensive laminated version. I use that for all my lenses, it takes no time at all to shoot it, adjust the MA, and try again. Past Equipment | My Personal Gallery
| Latest registered member is griggt 1103 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
