Thread started 14 Jun 2013 (Friday) 19:05
Elements 10 Showing more blown highlights than my 600D.
Colin ­ Glover
Gallery: 17 photos
Joined Aug 2012
Jun 14, 2013 19:05 |  #1
Why is Elements 10 showing more blown highlights than my 600D does? I had to shoot JPegs for my last shoot, including some sunsets, but opening them as Camera Raw files using the 'Open As' command reveals loads more blown highlights, even though they don't look too bleached out. What's the problem? The camera or Elements?
Regards,
Col.
Canon EOS 70D, Canon EOS 600D, EF-S 18-55 ii, EF 55-200 USM ii, EF-S 75-300 iii, Tamron 28-80, Sigma 70-210. Pentax 50mm, Pentax 135mm, EF-S 55-250, Raynox Macro adapter, Neewer filters (CPL, UV, FLD & ND4), Fuji HS20 EXR (30X zoom ) & cable release, Yongnuo 560 iii & Luxon 9800A manual flashguns for the Fuji, Hama Star 63 tripod, Hongdek RC-6 remote control, Velbon DF 40 www.point-n-shoot.co.uk website.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Jun 14, 2013 20:36 |  #2
To clarify, when you said "opening them as Camera Raw files" you meant that you opened them in Adobe Camera Raw ... correct?
In your camera and in ACR, what color space is your output set to, aRGB or sRGB? If the camera is aRGB and ACR is set to convert files to sRGB, an image that has no clipped shadows or highlights from the camera can show significant clipping with the ACR histogram. The same thing will happen if your working color space in Photoshop is sRGB. If the image from the camera is aRGB and you convert to an sRGB PS working color space then the PS histogram can show clipping.
Bob
Wilt
Jun 14, 2013 22:29 |  #3
The way in which your camera records the embedded JPG preview within the RAW files is NOT assumed to be the same parameters as used by a RAW convertor (only CPP tries to use the camera settings in doing intial RAW conversion)
ejenner
Gallery: 98 photos
Joined Nov 2011
Jun 15, 2013 00:14 as a reply to  @ Wilt's post |  #4
But he said he had to shoot .jpeg's.
What are you comparing - the image in ACR vs the camera LCD? How are you determining they are blown out of the camera - blinkies?
Honestly I don't have an answer, but hoping this is going to lead the conversation towards an explanation.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
Colin ­ Glover
Gallery: 17 photos
Joined Aug 2012
Jun 15, 2013 01:40 |  #5
EJenner, yes it's the blinkies I compare. Bob, what's the best, RGB or sRgb? And how do I change ACR to match?
Regards,
Col.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Jun 15, 2013 02:32 |  #6
If you don't have a clear understanding about color management you should stick to sRGB throughout.
- Set your camera to sRGB jpeg
- At the bottom of the ACR screen it will tell you wich color space you're using. Click on it and set it to 8 bit sRGB jpeg (while it doesn't really matter much, I'd also set resolution to 300 PPI).
- Set your working space for Photoshop to sRGB
Also, since you are shooting jpeg there is no need to use ACR. You can open the file directly into Photoshop.
Until you have a clear understanding of color spaces and the advantages and disadvantages of using larger ones like aRGB you really should keep things simple. Frankly, you'd get more benefit from shooting RAW than using a larger color space. Master an sRGB jpeg workflow first, then consider moving to a RAW workflow. You may find you'll never need to to work with large color spaces like aRGB or ProPhoto RGB.
Bob
760 views & 0 likes for this thread, 4 members have posted to it.
1669 guests, 135 members online
