Thread started 21 Jan 2006 (Saturday) 06:47
!! My quick and easy "Sky Fix"- #2 !!
delinian
Jan 21, 2006 06:47 |  #1
As some of you already know, I recently posted a thread titled
!! My quick and easy "Sky Fix" !!
Well.... In my never ending quest to find shortcuts in CS2, I came up with this.
I don't know if I'm "origional", or if this technique has already been discused here, or elsewhere, but in all my searching to learn, I haven't seen this method. This is quick, and easy. I have had success on .jpeg, .tiff, .psd, and raw, and works well on a sky that's not screwed-up, if you just need to enhance it a little.
No messed-up treeline.
Here's how:
Open photo in CS2 ( other ver. that allow gradient "color burn" will probably work)
Magic Wand>sky
Gradient Tool>choose Blue of your choice>choose Linear>
Mode ColorBurn>choose Opacity (I've had best success between 40-70 % )
drag gradient from top of photo to treeline. Badda Bing, done deal.
experiment with opacity to get results you want.
I edited a gradient, to create my own sky blue.
origional
Dennis
Delinian.com (external link)
mickle
Joined Aug 2004
Jan 21, 2006 08:55 |  #2
Add a quick play with this pic. There's a bit of a halo on the treeline, but it was a quick play...
Mike
Visit Mikes Scripts & Actions (external link) for:
Photoshop framing scripts for CS & CS2 & CS3
Framing Script for Photoshop 7 & CS
Dynamic Velvia script for CS & CS2
Framer Action Set for PS7
Framer Action Set for PS Elements
Mikes Framer thread
FlyACL
Jan 21, 2006 10:16 |  #3
Nice work! :)
rudgej
Couch-potato photographer
Jan 21, 2006 11:45 |  #4
Nice PP Mike! It is obvious your Photoshop skills extend past framing scripts. ;)
delinian
Jan 21, 2006 13:50 |  #5
Mike, would you mind explaining what you did? I'm trying to learn, and don't see the "halo" you fixed?
Dennis
mickle
Joined Aug 2004
Jan 21, 2006 14:09 as a reply to  @ delinian's post |  #6
replied to your PM.
Mike
Mikes Framer thread
mickle
Joined Aug 2004
Jan 21, 2006 14:11 as a reply to  @ delinian's post |  #7
The halo wasn't in the origonal, it was after I adjusted and sharpened. Having said that, on a second look it doesn't look too bad.
Mike
Mikes Framer thread
EOS_JD
Jan 21, 2006 14:50 |  #8
You could elimoinate that halo with a feathered selection of the sky on a mask. Once your action is done just change the pen to black and remove the halo.
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
chtgrubbs
Joined Jul 2003
Jan 22, 2006 00:05 |  #9
Here's my take. I selected the sky, made a layer from the selection and changed the blending mode to Linear Burn. Used a little curves and levels on the foreground.
1,899 views & 0 likes for this thread, 6 members have posted to it.
2153 guests, 126 members online
