Thread started 16 Jun 2013 (Sunday) 17:18
Convertor or lens advice please.
PeteD
Jun 16, 2013 17:18 |  #1
I have the 5.6 400 L and really like this lens. But in some cases I have needed a little more reach. Also, some of the outings I want to go on I know I will need more. So this is where I need the advice. I currently can not afford a 500 or 600mm L series Canon.
I am torn between a 1.4 along with a 2X convertor or maybe a 150-500 sigma. I know a lot of the great photogs on here have tried both. So, any advice will be taken seriously.
It will mostly be used for birding and wildlife photography.
Thanks in advance guys and gals.
I don't suffer from insanity. I enjoy it!!
52weeks completed (external link)
My 365 thread on the Camel (external link)
P & A Photos Flickr (external link)
P & A Photos Photobucket (external link)
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
Jun 17, 2013 01:51 |  #2
What camera body do you have? Obviously you will lose AF when you slap a TC on the 400 f5.6 if you don't have a 5d3 / 1d*...
Chris Marriott Photography (external link)| Facebook (external link)
Complete Gear | 1ds iii | 5d iii | 50d | EF 16-35 f2.8 L USM ii | EF 24-70 f2.8 L USM | Σ 70-200 f2.8 ii EX DG HSM | Σ 35mm f1.4 Art | EF 50mm f1.4 USM | EF 85mm f1.8 USM | EF 85mm f1.2 L USM ii | 600EX-RT | 580EX ii | 430EX ii | YN622Cs |
PeteD
Jun 17, 2013 05:03 |  #3
I have the 7D. I should retain auto focus with the 1.4 but not the 2X
kin2son
Joined May 2011
Jun 17, 2013 05:05 |  #4
PeteD wrote in post #16037976 (external link)
With Canon TC, no you don't, as 1.4x TC makes it a f8 lens.
Only 5D3 and 1 series body can AF @ f8.
Third party TC such as Kenko works, but it's slow and tends to hunt.
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
postcardcv
Jun 17, 2013 05:30 |  #5
I wouldn't bother with the 150-500 it will not offer you much more and is slower focusing than the 400 f5.6 and will be softer wide open. As has been said you will not get AF with either tc with your camera body (though it should AF if you use livevew with the 1.4x), and the image quality will take a bit of a hit. You might find that cropping a bit gives as good results as using a 1.4x, it would be interesting to test that. The 2x will definitey havea much bigger impact on IQ so you would be better off with the 1.4x if you do go for one of them.
www.blueskybirds.co.uk (external link)
gasrocks
Jun 17, 2013 08:14 |  #6
One should always get, or rent for a week, a 1.4x TC before even thinking about a 2x TC. I have used both with the 400/5.6 on a monopod and gotten great results. Of course, I only use MF. Gene
PeteD
Jun 17, 2013 17:26 |  #7
Thanks everyone for the help soo far.
I have read on here and other forums that you do have auto focus with the 1.4. Looks like it may be one of those things where I will just have to give it a try just to find out.
I knew I would lose it for certain with the 2X.
So, you guys think I would still be better with the convertor over the Sigma?
DreDaze
Gallery: 49 photos
Jun 17, 2013 18:00 |  #8
PeteD wrote in post #16040053 (external link)
the difference in reach between the 400mm, and the long end of the 150-500mm(which is supposed to be somewhere around 480mm) isn't enough to justify the change in my opinion...the sigma needs to be stopped down to f8 to get good center sharpness...and even then you're probably giving up better AF for it... one possible thought could be along the lines of the sigma 120-300mm f2.8 OS with TCs...although that's a lot more money
Andre or Dre
gear list
Instagram (external link)
gasrocks
Jun 17, 2013 18:00 |  #9
Unless you tape over 3 pins, you will indeed lose AF with a 1.4x.
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
Jun 18, 2013 02:39 |  #10
If you get something like the Kenko TC then yes your 7d will probably try and AF with the 1.4x extender... it won't be as quick as normal though. It's not supposed to focus, and a Canon-specific extender wouldn't work... only the 5d3/1d* bodies can AF on the centre point at f8 as mentioned above. Taping the pins as gasrocks mentioned is a way of tricking communication between the TC and the camera so the camera doesn't know the lens is now an f8 lens, hence it still tries to AF. I don't know what you've read elsewhere, but don't buy a 1.4x TC and expect it to operate as normal on your 7d...
PeteD
Jun 19, 2013 20:52 |  #11
Well, I got to borrow a 1.4 today to try out. I did have auto focus . Albeit it was in high noon lighting. Who knows with any other type. It was a little on the slow side but, did work
Havce read that the IQ is about the same between the 1.4 and the siggie so I may just save quite a bit and go with the convertor.
1,647 views & 0 likes for this thread, 6 members have posted to it.
866 guests, 129 members online
