Thread started 16 Jun 2013 (Sunday) 20:34
Remote shutter release with 600EX-RT and ST-E3-RT
swldstn
Jun 16, 2013 20:34 |  #1
So I can place my ST-E3-RT (as a master) on the 1DX or 5DIII and trigger the camera from the remote 600EX-RT set up as a slave. Then using menu2 to bring up the REL and trigger it all.
Now is there anyway to reverse the process and use the flash as a master at the camera and trigger the camera from a ST-E3-RT held in my hand?
Also currently if I want to use my Sekonic 758DR with the Canon 600EX-RT flashes and ST-E3-RT I ended up getting a Pocket wizard to trigger the camera, which, triggers the flashes. It works great but using two radio systems is a little bit of a pain and pretty expensive. Anyone got any better ideas here as well.
Steve Waldstein
Love to Shoot - a Digital SLR (and now a Mirroless ILC) are my weapons of choice
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Jun 16, 2013 23:16 |  #2
I have not explored this but with the cameras you mentioned there is a linked shooting option which would I think would do what you asked. Pg 70 of the manual which I can post here upon request.
You cannot use your Sekonic to fire any Canon RT gear. Canon RT only plays nice with Canon RT. I called Sekonic and they have no plans to develop a Canon friendly RT module. I carry my STE3 with me along with my L-358. I fire the flash/flashes in manual and group mode with the STE3 test button and adjust flash output power via the STE3 at each flash location. I cut the foot stand to size and attached a spare BR connector.
IMAGE: http://i33.photobucket.com/albums/d74/Zenon1/_S7A9539.jpg
Image Editing OK
swldstn
Jun 17, 2013 18:06 |  #3
What I have not found is a way to set up the ST-E3-RT to do remote shutter release when its not on the camera as a master. I would like to carry it and then use it to trigger the shutter release on either another ST-E3-RT on the camera or if necessary an 600EX-RT.
As I said in my original post the other way around works. Where a 600EX-RT slave with REL on menu2 is used can trigger a ST-E3-RT to release the shutter.
Steve Waldstein
PacAce
Joined Feb 2003
Jun 17, 2013 18:43 |  #4
swldstn wrote in post #16040172 (external link)
Have you tried setting up the camera, flash and the ST-E3 RT for Linked Shooting? Below is an excerpt from the "Linked Shooting" chapter:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/06/3/LQ_653157.jpg
Image hosted by forum (653157) © PacAce [SHARE LINK]
...Leo
swldstn
Jun 17, 2013 21:58 |  #5
Leo, this is almost there.
a) Set ST-E3-RT (off camera) to Master Linked and set the channel and ID of the ST-E3-RT (per the detailed directions)
b) Set 600EX-RT (on camera) to Slave Linked and set the channel and ID to match the ST-E3-RT
The ST-E3-RT has the REL button and it will trigger the shutter on the camera. But the flash won't go off but maybe its not really meant to? Just need that third step which I'm not sure of but I've made some progress. I do have two more 600EX-RT to add to see what I can figure out.
Anyone else have an idea if I'm missing a step. Did check that the camera has the flash firing enabled ( a tip in the manual).
Steve Waldstein
swldstn
Jun 18, 2013 18:59 |  #6
Come on! Someone must know the missing step on how to do this. Or if you know its not possible let us know.
Steve Waldstein
apersson850
Gallery: 35 photos
Jun 21, 2013 09:02 as a reply to  @ swldstn's post |  #7
It's personal function 7 (P.Fn 07) in the flash that controls whether the linked slave camera's flash units will also fire, not just release the camera they are mounted on.
Can't be set from the camera, but has to be set on the flash itself.
Anders
swldstn
Jun 26, 2013 21:26 |  #8
Will give it a try
Steve Waldstein
swldstn
Jun 26, 2013 21:50 |  #9
apersson850 wrote in post #16051360 (external link)
Anders nailed the missing piece! Here are my steps now.
a) Set ST-E3-RT (off camera) to Master Linked and set the channel and ID of the ST-E3-RT (per the detailed directions).
c) set the personal function 7 (P.Fn 07 ) on the on-camera 600EX-RT to 1:On for linked shot. This is done by going to Menu 3 and first holding down the Zm/C. Fn button till it gets in C. Fn mode and the select P. Fn and set option 07 On.
Now your ready. The off camera ST-E3-RT will trigger the shutter using the on-Camera 600EX-RT when you press its REL Button and also trigger the slave flashes!
Steve Waldstein
Palladium
Jun 26, 2013 22:04 |  #10
swldstn wrote in post #16068427 (external link)
thanks will try tomorrow
PacAce
Joined Feb 2003
Jun 26, 2013 22:18 |  #11
The ST-E3 doesn't trigger the slave flash, does it? If it did, then it wouldn't be in sync with the camera that's also triggered by the ST-E3. The ST-E3 triggers the camera which in turn triggers the on-camera flash via the hot shoe connection, right? :)
...Leo
apersson850
Gallery: 35 photos
Jun 27, 2013 05:08 as a reply to  @ PacAce's post |  #12
Technically yes. But since there's no flash from the ST-E3-RT, it looks like it's the same thing.
I tried putting a 600 EX-RT on a 7D, flash in linked shooting master mode, then putting another 600 EX-RT on the 1DX, flash in linked shooting slave mode. This setup works so that when you take a picture with the 7D, then the 1DX will follow suit a few tenths of seconds later.
If you then set P.Fn 07 on for both flashes, the time difference between the two is of course much more noticeable than it is between a non-flashing master and the slave. Even if it really is the same.
Other cameras than a 1DX can be slaves too, but a 7D for example requires an SR-N3 remote trigger cable.
Anders
swldstn
Jun 27, 2013 18:06 |  #13
PacAce wrote in post #16068501 (external link)
Well, the ST-E3-RT off camera as the master in linked mode.
I believe it first communicates to the linked slave to trigger and then the camera triggers the flash but for me there is no real way to tell if the slave is doing both. i.e. triggering the camera shutter and flash at the same time. Does anyone have a way to tell?
Steve
p.s. I'm just happy I finally got it working.
Steve Waldstein
PacAce
Joined Feb 2003
Jun 27, 2013 19:53 |  #14
swldstn wrote in post #16070992 (external link)
Steve
Yes, it's very easy to tell. If the flash lit the shot taken by the camera, then it was triggered by the camera and not the ST-E3. If the flash isn't evident in the shot, then the flash was triggered by the ST-E3. ;)
...Leo
apersson850
Gallery: 35 photos
Jun 28, 2013 03:01 as a reply to  @ PacAce's post |  #15
No worries, it works. I've tried the same thing, almost. The only difference was that I used two 600 EX-RT, instead of one ST-E3-RT and one flash. You can even use several cameras, with flashes and/or transmitters on both, and fire one camera with the master and the slaves will follow. In that case the master camera's flash (if there is a flash, and it's set to fire) will fire a split second before the slaves. Then the slaves fire more or less at the same time, and if they do manage to fire at the same time (longer exposure times makes this more probable), then there's a clear risk that they illuminate each other's images. That's why the default setting here is that the linking flash does not fire, just release the slave camera. But if you do set it to fire, then it will fire in sync with the camera it's mounted on.
Anders
7,649 views & 0 likes for this thread, 5 members have posted to it.
1361 guests, 170 members online
