Thread started 18 Jun 2013 (Tuesday) 15:47
Best method to clean 60-year-old 35mm slides ?
sue.t
Gallery: 30 photos
Jun 18, 2013 15:47 |  #1
Dad took thousands of photographs of Yukon in the 1950s & 1960s, most on 35mm slides. I wish to scan many of these. Some have embedded dirt, some have fingerprint stains on them, some look spotty.
DIGITAL ICE Technology does a reasonable job of healing the dirt while scanning.
BUT if I wished to clean the slide beforehand, what would you recommend?
Part of my dilemma is I live in Yukon where the best photography store is Walmart (no snickering!). So I need a practical solution using easily available products.
Google searching shows some recommend rubbing alcohol, some say 100% alcohol, some talk about specific slide cleaning fluids.
Rubbing alcohol & Q-Tips are tempting ... will this damage the slides?
Thanx in advance for assistance with this.
Here is an example of his photography, this at Snag, Yukon in the early 1950s:
IMAGE: http://suethomas.ca/images/Historical/JacksYukon_9A.jpg
G3G4G5
Jun 18, 2013 17:27 |  #2
Dollar 19s! Great photo.
Chris
1D Mark IV, 7D, EF 500mm f/4L IS, EF 100-400mm f/4.5-5.6L IS II, EF 70-200mm f/2.8L IS II, EF 24-70mm f/2.8L, EF 17-40mm f/4L
sue.t
Gallery: 30 photos
Jun 18, 2013 17:56 |  #3
Ummm ... yup, Flying Boxcars. Dad was a pilot too and took many photographs of the aircraft that landed at Snag, Yukon.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Jun 18, 2013 21:21 |  #4
Here you go:
http://www.bhphotovide​o.com …91276201&Ntt=fi​lm+cleaner (external link)
Check the labels on any of these film cleaners and use appropriate precautions, including reading the MSDS sheet for the product. Most are pretty volatile and contain chlorinated or fluorinated hydrocarbons, so you need to use under good ventilation and keep the solution from contacting your skin.
I used to use Kodak Film Cleaner, but it contained a 1,1,1-trichloroethane and 1,2,2-trifluoroethane, which aren't nice chemicals to be coming in contact with (1,1,1-trichloroethane used to be in the original versions of white-out).
Bob
sue.t
Gallery: 30 photos
Jun 18, 2013 23:13 as a reply to  @ Bob_A's post |  #5
Thank you, Bob.
I had read about trichloroethane and trifluoroethane, with comments indicating these were very effective and would not damage the slide.
Hopefully there will be no issues shipping these chemicals across the border. If so, will maybe attempt a trip to Anchorage to see if I can purchase there.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Jun 19, 2013 00:20 |  #6
sue.t wrote in post #16044089 (external link)
Thank you, Bob.
Instead of shipping across the border check with TheCameraStore in Calgary or McBains or Vistek in Edmonton.
Bob
Mavgirl
Joined Mar 2013
Jun 19, 2013 21:09 as a reply to  @ Bob_A's post |  #7
Beware of putting the cleaner on the emulsion side of the film. Some of them will damage the emulsion side of old films (like Kodachrome), especially if the emulsion has already been compromised. I found that one out the hard way (using PEC-12).
Attack it with a rocket blower first and see how far that gets you. Also keep cleaning your scanner because it will get dirty fast.
6D/50D/350D with too many lenses
Calumet 4x5, Pentax SV 35mm, Canon A-1, Rebel G and many more toys...
Bob_A
Gallery: 48 photos
Joined Jan 2005
Jun 19, 2013 22:08 |  #8
Mavgirl wrote in post #16046916 (external link)
You bet. Some cleaners are better than others for the situation. It's also a good idea to test with a "scrap" slide or at least the worst slides to ensure things go well.
For slides and negatives I'd use Dust-Off instead of a Rocket Blower. It's quicker, safe for the emulsion and does a better job removing slightly stuck debris.
sue.t: For thousands of slides or negatives I'd also strongly consider sending them off to ScanCafe instead of doing them myself. :)
Bob
Nightstalker
Jun 20, 2013 01:08 |  #9
Try asking the same questions on http://www.retouchpro.​com (external link) - they have some real experts on this sort of restoration.
HelplessSEAL
Joined Jun 2012
Jun 20, 2013 10:33 |  #10
Perhaps some photo-flo diluted in water? It's an educated guess based on my experience with film.
Epic battle in my mind of whether to focus more on portraiture or architecture. #FirstWorldProblems :roll:
Mavgirl
Joined Mar 2013
Jun 20, 2013 13:15 |  #11
HelplessSEAL wrote in post #16048409 (external link)
On really old emulsions that may have softened, become brittle or have been damaged you want to avoid water. It can get in between the film and the emulsion layer and strip it right off.
OP... another option that just occurred to me is to try wet scanning. It will help eliminate the dust and scratches somewhat. I'd test it on a scrap slide as suggested already though.
6,808 views & 0 likes for this thread, 6 members have posted to it.
1318 guests, 132 members online
