FORUMS Post Processing, Marketing & Presenting Photos The Business of Photography
Thread started 19 Jun 2013 (Wednesday) 11:50
Educating clients on print size/ratio differences
NewCreation
Gallery: 47 photos
Joined Jan 2013
Jun 19, 2013 11:50 |  #1
I did a search but maybe I need different terms because I could find a thread. If there is one, please just point me there. Thanks
Here is my question. How do you educate clients about print sizes and how the 527 or 8x10 they want to order is going to look different than their 4x6 proof?
I am just trying to think ahead on how I want to do this. I am very visual so I thought I'd get a 4x6, 5x7, and 8x10 of the same shot as an illustration tool. Then find some what to show which sizes would correspond if the print were bigger. (ie the 20x30 print would crop the same as the 4x6).
Just curious how you all do it. Or is it not really a big concern?
My name is Brenda ~Saved by grace, walking by faith
http://brendahoffmanph​otography.com (external link)
Facebook (external link)
Luckless
Joined Mar 2012
Jun 19, 2013 12:09 |  #2
Print off the larger ratio photo with the smaller crop outlined in red. Best visual method I can think of.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
jwhite65
Gallery: 24 photos
Joined Feb 2013
Jun 19, 2013 12:39 |  #3
Get a clear 4x6 sleeve and outline the 5x7 and 8x10 crops on it (maybe one on each side). Slip the photo in to illustrate the crop.
Jeff
http://www.jeffwhiteph​otography.com (external link)
5D MkIII | 5D MkII | 70-200 f/2.8L IS II | 24-70 f/2.8L | 50mm f/1.4 | 600EX-RT (3) | ST-E3-RT
NewCreation
Gallery: 47 photos
Joined Jan 2013
Jun 19, 2013 14:48 |  #4
Luckless wrote in post #16045486 (external link)
jwhite65 wrote in post #16045548 (external link)
Is this what you do for your clients? Is it effective?
skippix
Joined Mar 2013
Jun 19, 2013 16:51 |  #5
NewCreation wrote in post #16045925 (external link)
it is effective for those that need it ;)
if your images are shot loose enough, it's usually not an issue. it's only on the tight and/or odd shots that it's an issue. for instance a large group shot that should be printed at a pano ratio (20x10) that is going to be printed as an 11x14 or 5x7 is sometimes hard to explain without showing the client.
Skip
feel free to visit my website (external link) | some resources (external link) | collections (external link) | epic panoramics (external link)
"If you don't know where you're going, you'll probably wind up somewhere else" - David Campbell, PhD
Luckless
Joined Mar 2012
Jun 19, 2013 16:54 |  #6
I don't have clients in photography, but have had to explain similar ideas to various people over the years. Visual methods that allow direct comparisons tend to work best in a lot of cases.
Another more complex option would be to make yourself a set of square rules, marked off so that you can show cropping of an image on the fly. Just use heavy card stock or something that is easy to work with. That way you can place a decent sized test image at the largest ratio on the table before the client/student, then use the card stock squares to mask the areas that would be lost for different cropping options. It not only allows you to demonstrate to them the various ratios but also allows you to show the effect of cropping smaller sections.
Going with the physical prop route means you have something for tactile learners as well as visual learners. You can do the same thing on a computer screen, but some elements may be harder to grasp for a given set of people with a different learning style.
NewCreation
Gallery: 47 photos
Joined Jan 2013
Jun 20, 2013 07:52 |  #7
skippix wrote in post #16046268 (external link)
Ha! I think sometimes that I'm the one that needs it most. ;) Good point on the group shot. I will keep that in mind.
Luckless wrote in post #16046274 (external link)
Thanks. I'll definitely go with something physical. It just helps my puny brain, too. I'll have to really stretch my brain to translate your square rules idea into real life. If you had provided a picture, I would have gotten it a lot quicker. lol
AdoriaPhotography
Joined Apr 2012
Jun 24, 2013 01:51 |  #8
On my wife's photography website (based on wordpress with woocommerce and nextgen plugins) I ended up building a customized preview gallery which allows customers to preview and alter the cropping as photos are being added to the shopping cart. It was a lot more complicated than I initially intended but it essentially uses a cropping api to define the intended crop region before adding the photo to the cart. The crop shape is based on the ratio of the selected photo size and the cropping coordinates are stored in the shopping cart.
In reality, few customers alter the default cropping guide for each image, but it does give them a visualisation of what they are likely to get.
Here is an example:
https://adoriaphotogra​phy.com.au …at-rhtc-expires-310712-2/ (external link)
Note: for Intellectual property reasons I cannot provide the code, but am just sharing the idea here as an example of what could be possible.
Regards, Steve - Adoria Photography (external link)
5d MKii | 70-200mm F2.8L IS USM ii | 24-70mm F2.8L | 50 F1.4 | 28-135 IS USM | Phottix Odin | Phottix Strato ii | 580ex2 | 430ex2 | 2 x YN-560ii | Kacey Beauty Reflector
jra
Jun 26, 2013 17:23 |  #9
IME, aspect ratio has rarely ever been an issue.....I usually don't even bring it up with customers unless it's somehow going to substantially impact the final product (which is almost never because I make it a point to shoot loose enough to crop to all common aspect ratios).
NewCreation
Gallery: 47 photos
Joined Jan 2013
Jun 26, 2013 18:29 |  #10
AdoriaPhotography wrote in post #16059234 (external link)
Here is an example:
That's pretty awesome! You could easily sell it.
jra wrote in post #16067761 (external link)
Thanks for the feedback. There are probably other things I should concern myself with before I worry too much about it.
2,099 views & 0 likes for this thread, 6 members have posted to it.
868 guests, 162 members online
