Thread started 19 Jun 2013 (Wednesday) 12:56
Heavy duty tripod advice...
nellyle
Joined Jan 2012
Jun 19, 2013 12:56 |  #1
...in September I shall be adding a 500 F4 ii and 5D3 to my arsenal. At present I have a Manfrotto 055XProb that I use with a 498RC2, not the most cutting edge gear but good enough for what I use it for, these items will not work well with my future purchases.
I've had a look at Gitzo tripods and to be honest I'm lost in all the different options, although I have decided that I don't need a centre column but that's pretty much it.
The Wimberly Gimbal seems to be the most liked, also the priciest. Is it really worth more than other brands?
All help appreciated!
5D3, 7D2, 1D3, 40D, 14 f2.8 Samyang, 17-40 L, 28-80 L, 70-200 2.8ii L, 200 2.8ii L, 200-400 L, 1.4 ii,
http://chris-stamp.smugmug.com/ (external link)
icassell
Jun 19, 2013 13:02 |  #2
I use an Induro GHB2 gimbal with my 500/4 and love it. It is smooth operating and sturdily made and costs considerably less than the Wimberly, last time I looked. I have an Induro AT-214 tripod which I like (although it is a bit on the light side. I've been considering stepping up to the 314). I took out the long center column immediately and replaced it with the optional short column so I could get down to near-ground level (I shoot primarily birds) and I don't miss the column a bit (I'm 6' tall).
Ian - http://www.icassell.sm​ugmug.com (external link)
Canon 7D2, 7D, 30D, Canon 500 f/4L, Canon EF 400/5.6L, Canon 70-200/2.8L II, Canon 100/2.8 Macro, Tamron 17-50/2.8, Canon 50/1.8 Mk I, Canon 40/2.8 STM, Rokinon 8/3.5 FE., Sigma 10-20EX/4-5.6, Sigma 1.4X and 2X EX, Canon 1.4x II, Induro CT313/AT214/GHB-2, Canon 600EX-RT, Olympus TG-3
nellyle
Joined Jan 2012
Jun 19, 2013 13:04 |  #3
Many thanks, I shall have a read up.
ghost68
Joined Jan 2012
Jun 19, 2013 13:25 |  #4
Take a look at the Feisol 3371/3471 (3/4 leg section pods) My 3471 is a beast! I just shoot a 100-400 with a 1.4 but its definitely very stable.
Smugmug (external link)
waterrockets
Joined Jun 2010
Jun 19, 2013 14:05 |  #5
icassell wrote in post #16045617 (external link)
One note on columns and ground shooting. Some tripods allow you to put the center column in upside down, and you can send it all the way down to the ground with a head and body/lens on it. This allows you to leave the legs in a normal orientation, and you don't have to splay them to the point of being a springy platform for a ground shot. Of course, there's the minor concern of using your camera upside down, but that might be easier bent over anyway :P
1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
icassell
Jun 19, 2013 14:42 |  #6
waterrockets wrote in post #16045799 (external link)
I may be wrong, but I don't think this system would work well with a gimbal and long lens. The camera wouldn't be upside down, because you mount the gimbal to the lens ring and not the camera, but it doesn't seem like you would be able to track very easily.
waterrockets
Joined Jun 2010
Jun 19, 2013 14:48 |  #7
icassell wrote in post #16045909 (external link)
Good point! Actually, ball/pan head and lens ring are the same result, and you can spin the camera right-side up.
swldstn
Jun 19, 2013 19:05 |  #8
I use a Gitzo GT3530LS with either a Markins Q20 with Wimberley Sidekick or Wimberley WH-200 Gimbal
Use the ball head a lot and carry the sidekick if I might need to switch over. Or if I know its only a long lense day I take gimbal and leave the ball head at home.
Highly recommend all of these.
Steve Waldstein
Love to Shoot - a Digital SLR (and now a Mirroless ILC) are my weapons of choice
Phoenixkh
a mere speck
Gallery: 67 photos
Joined May 2011
Jun 19, 2013 19:08 |  #9
I recently purchased a RRS tripod and monopod. The quality is beyond amazing. They weren't cheap but they are a joy to use. Simple, stable, and built to last a lifetime with proper care.
Kim (the male variety) Canon 1DX2 | 1D IV | 16-35 f/4 IS | 24-105 f/4 IS | 100L IS macro | 70-200mm f/2.8L IS II | 100-400Lii | 50 f/1.8 STM | Canon 1.4X III
RRS tripod and monopod | 580EXII | Cinch 1 & Loop 3 Special Edition | Editing Encouraged
J ­ Michael
Jun 19, 2013 19:20 |  #10
Have you thought about size constraints, such as length when folded? If you intend to pack it for travel you may need one with 4 sections rather than 3. When looking at weight ratings look for one that is rated 2 or 3 times the amount of weight you intend to put on it. Sirui M series might be an option.
yogestee
Jun 19, 2013 23:08 as a reply to  @ J Michael's post |  #11
I see you are in the UK. I believe Paterson still have Benbo tripods. I still have a Benbo Classic No 2 which I bought in the early 1980s to mount medium format and 4x5 cameras on. The Benbo is the toughest tripod I've ever used.
Check them out.
http://www.patersonpho​tographic.com/benbo-tripods.htm (external link)
Jurgen
philwillmedia
Jun 19, 2013 23:35 |  #12
I've just bought a Vanguard Tracker 1.
It's a pretty good unit and takes the weight of a 1 Series body and 300/2.8 with no probs.
Can't see that it will have a problem with a 400/2.8 or anything longer.
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
nellyle
Joined Jan 2012
Jun 20, 2013 01:37 |  #13
Thanks for all the replies, plenty to go and look at now!
What with the time difference between me and all of you, I hope you don't think I was ignoring, I was just asleep!
Size isn't too much of an issue (3 or 4 sections) as most of the time I shall not be hiking too far from car or home.
hollis_f
Jun 20, 2013 03:38 |  #14
There are several companies that now produce gimbal heads that are up there with Wimberly, but not quite as expensive. I use a Jobu after using a Wimberly on long-term loan and there's no real difference.
One thing to check on is that the platform can be raised/lowered so that the axis of rotation goes straight through the centre of gravity. If it doesn't then the lens won't stay put at an angle without some friction.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
nellyle
Joined Jan 2012
Jun 20, 2013 08:27 |  #15
hollis_f wrote in post #16047642 (external link)
Thanks for the heads up, I hadn't seen them before.
I assume you use that with your 300....my other option is the new 300 and a 1DX (instead of 500 and 5D3) I had a brief email chat with Andy Rouse, and he seemed to think that the 300 option would be better, especially as the version 2 lenses seem to work well with the new converters.
I find it hard to get over the length advantage of the 500 though!
Whichever option I go for, its use is going to be for UK wildlife, its first proper outing will be a solo week on Skye.
6,813 views & 0 likes for this thread, 17 members have posted to it.
1193 guests, 136 members online
