Thread started 20 Jun 2013 (Thursday) 15:17
Lightroom Benchmarks
silvrr
Gallery: 13 photos
Jun 20, 2013 15:17 |  #1
I often see people asking for recommendations on this forum for computer hardware for lightroom use and I often wonder what the cost in upgraded hardware (say a i7 3770K vs i5 3570K) gets you in lightroom. There is a benchmark thread for Photoshop but I haven't seen anything for Lightroom. I know with the users on this forum we could put together a pretty good comparison of hardware. I haven't wanted to for some time but haven't had the time. Seems like we would need to compare a few main parts.
CPU:
- Cores (2 vs. 4 vs. 8 vs. 12)
- Clock Speed
I have tested clock speed but not cores on my rig. Clock speed does make a difference but not a lot. Cores should be easy, I can test 4 with my 3570K and then drop two and retest for example. Not sure if anyone is running a 6c 12t chip on here but would be interesting to see.
RAM:
- Amount (2GB vs. 4 GB vs. 8GB. vs. 16)
- Frequency (1333 vs. 1600 vs. 1866 vs. 2133 ect)
This should also be easy to test by removing RAM (we would need to keep pairs for dual channel setups) and re-testing. Frequency should also be easy as someone with 2133 RAM could run any speed under that with a few BIOS changes.
Disk:
- 5400RPM vs. 7200RPM vs. SSD
This one is a bit more complicated as I am not 100% sure how Lightroom uses files. For import I think it would effect where they are stored. However, after that I am not sure if they are ever accessed again from the original location. I would want to understand the cache usage and how the files are stored and used before making setups to test.
GPU:
Everything I have read says the GPU isn't touched by lighrtroom (except for display). Therefore, I don't see a need for any tests.
Benchmarks:
I think we would need to have everyone use the same RAW files to keep things consistent. Getting everyone those files is something I would have to figure out. I would be interested to see tests of maybe 50 RAWs run in a batch. The larger batch helps take out some of the timing errors.
Test 1: Render 1:1 previews
Render 1:1 previews for the 50 RAW photos.
Test 2: Processing
Process a batch of 50 RAWs with the same preset.
Test 3: Export
Export the 50 RAWs to disk.
I think that would cover it and give a good idea on the performance differences. Anyone have any comments on tests, setups, protocol on tests ect.? Maybe I should have left it at is anyone even interested in the benchmarks.
Test Setup:
Mobo: ASUS Z68-M Pro
CPU: Intel i5 3570K (@Frequency noted)
RAM: 16Gb G-Skill Ares (@ Frequency noted Timings always 11-11-11-30)
SSD: Crucial M4 64GB (OS and programs loaded ~48% full)
HDD: WD Caviar Black 500GB 64MB cache 7200 RPM (Storage ~77% full)
Windows 7 64 bit
Lightroom 4.4 64 bit
The same 50 RAW files were used for each test. The computer was started with the noted settings, a catalog created, files imported and as quickly as possible 1:1 preview renders started. Lightroom automatically starts this so there is a bit of variability but the tests were shown to be repeatable. Then after the preview test the files were exported to the SSD. Then the export location was changed and the files exported to the HDD. The catalog and cache were cleared before each change in test settings and restart. The recycle bin was emptied before restarting to not build up data on the SSD.
The cache size was fixed at 20GB available. 1:1 preview settings were (Jpeg Preview (dng, Full Size, Preview Size 1440 pixels, Preview Quality Medium). Export was full resolution JPEGs with no export processing applied.
Disclaimer:
Timing is done with my iPhone and done to the best of my ability but some variability in the start stop timing is obviously there. I ran the 3500 mhz test 5 times at the beginning to ensure the test was repeatable and all results were within less than a second.
I did my best to think of things that would effect the results (clearing cache, clearing the catalog, no extra processes running, ect.) but please point out any flaws in my methods.
Past Sale Feedback
cschultz
Joined Jun 2013
Jun 20, 2013 15:25 |  #2
should be very interesting and very informative. cant wait for the results. if i know what i was doing with lightroom and had a good copy id run the same tests on mine. maybe in the future!
6D gripped|50mm F1.4|300 F/4 L| 70-200L F4|24-105L| 430 EX II| 320EX
emorgn
Joined May 2012
Jun 21, 2013 18:59 |  #3
I'm very interested in this!!
Canon EOS 7D Mark II | Canon EF 35mm f2 IS USM | Canon EF 50mm f1.8 STM | Canon EF-S 18-135mm f/3.5-5.6 IS STM | Canon EF-S 10-18mm f/4.5-5.6 IS STM | flickr (external link)
Canon EOS T3i | Canon EF-S 18-55mm f/3.5-5.6 IS II | Canon EF 50mm f/1.8 II | Canon EF-S 55-250mm f/4-5.6
silvrr
Gallery: 13 photos
Jun 21, 2013 19:33 |  #4
Well got started on this a bit and ran into a few hiccups. My motherboard won't let me underclock my CPU. I may just be missing a setting but Ill have to do 3500 MHz to 4200 MHz for now. If its a linear relationship I may just be able to graph them and get a general idea of what below 3500 and above 4200 would look like.
Second issue was the processing. If I create a preset with a bunch of changes and then select the whole catalog. It applies it but doesn't actually process each photo. Have to figure out something to test that.
The 'import' benchmark was also clairfied to generating 1:1 previews. Import is almost instant, I generate all my 1:1 previews upon import. It takes some time and loads the processor pretty well.
Past Sale Feedback
silvrr
Gallery: 13 photos
Post edited over 8 years ago by silvrr. (2 edits in all)
Jun 22, 2013 00:37 |  #5
Some preliminary results. I had results for the dropping cores too but my laptop took a dump and I lost all 4 tests.
Anyway on to the results.
Exporting to the SSD vs. HDD. The same. I was surprised by this, especially across frequencies but I have seen it before too when I ran some tests in the past. I may try putting the source images on the HDD and seeing if it effects the time to make 1:1 previews.
Changing CPU frequency. I see this come up quite often when people ask if they should get processor X or Y and the only real difference is frequency. It does make a difference but keep in mind that is over 50 photos. From 3500 to 4200 MHz there is a 18 second difference or 0.36 seconds per photo.
IMAGE: http://i111.photobucket.com/albums/n143/silvrr600/CPUFrequencyChange_zps10170c62.jpg
IMAGE LINK: http://s111.photobucke​t.com …ange_zps10170c6​2.jpg.html  (external link)
Changing RAM frequency. This comes up in many hobbies and it is really overblown a lot of the time. A 5 second difference over 50 photos or 0.1 seconds per photo.
IMAGE: http://i111.photobucket.com/albums/n143/silvrr600/RAMFrequencyChange_zpsb21d2acb.jpg
IMAGE LINK: http://s111.photobucke​t.com …ange_zpsb21d2ac​b.jpg.html  (external link)
The data for anyone interested.
IMAGE: http://i111.photobucket.com/albums/n143/silvrr600/Data_zps1129fe68.jpg
IMAGE LINK: http://s111.photobucke​t.com …Data_zps1129fe6​8.jpg.html  (external link)
Past Sale Feedback
silvrr
Gallery: 13 photos
Jun 22, 2013 00:52 |  #6
A look at how Lightroom uses the CPU and RAM. Its a bit harder to see on the RAM due to the scale but the usage on both surge up and down as each photo is either Rendered for a 1:1 preview or exported to JPEG.
Never went over 2.5 GB of RAM usage for either operation. The big RAM usage that some report I think is when using some of the processing tools (brushes, gradients, ect.)
Rendering 1:1 Previews:
IMAGE: http://i111.photobucket.com/albums/n143/silvrr600/1to1PreviewUsage_zps29c71e76.jpg
IMAGE LINK: http://s111.photobucke​t.com …sage_zps29c71e7​6.jpg.html  (external link)
Exporting:
IMAGE: http://i111.photobucket.com/albums/n143/silvrr600/ExportUsage_zps74465b54.jpg
IMAGE LINK: http://s111.photobucke​t.com …sage_zps74465b5​4.jpg.html  (external link)
Past Sale Feedback
silvrr
Gallery: 13 photos
Jun 22, 2013 01:31 |  #7
A couple more quick tests before bed because I got curious. Tried putting differnt parts of the data on a RAM Disk. A RAM disk is extremely fast and is basically just a chunk of RAM setup by software to act like any other disk. Only issue was the Catalog couldn't be put on it as Lightroom saw it as a volatile drive (power goes off you lose your catalog) and I couldn't export to it due to permissions issues. Small gains using the RAM disk. Ill test with the HDD soon.
IMAGE: http://i111.photobucket.com/albums/n143/silvrr600/Capture_zpsdce0280c.jpg
IMAGE LINK: http://s111.photobucke​t.com …ture_zpsdce0280​c.jpg.html  (external link)
Past Sale Feedback
silvrr
Gallery: 13 photos
Jun 22, 2013 11:16 |  #8
Tried to knock out the HDD tests this morning. Had some intresting results. I was getting in the 104 range for the 1:1 test at first and thought maybe splitting the load was helping speed things up slightly. Then I put all the tasks on the HDD and got the same result 104. So I re-ran the tests with everything on the SSD and got 104. I then re-checked the all SSD test and 104 again. Re-checked two of the HDD options and 104 again.
I honestly have no idea what changed overnight. I shutdown overnight and when I restarted I confirmed all the settings in CPU-z just to be safe. Nothing changed. I guess it goes to show that other things can effect the speed of the work as much as faster RAM or a few thousand MHz bump.
Anyway, updated results.
Ill try to work on the core changes today. The results were pretty interesting, I expected a more linear result but its actually exponential.
Past Sale Feedback
René ­ Damkot
Jun 22, 2013 12:43 |  #9
Most important (IMO) isn't how fast LR renders an export, but how responsive it is while editing images.
A small change there can feel like a big improvement.
But how to test that? Maybe change all "basic" sliders on an image a set amount, and measure the time until the image is updated? Then again, if you can reliably measure that time, LR would probably feel "too slow" ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
silvrr
Gallery: 13 photos
Jun 22, 2013 13:15 |  #10
René Damkot wrote in post #16054876 (external link)
Yeah that is the one that is being tricky. I use 50 images to get a good run time and take out timing errors but haven't figured out a way to batch process/edit yet. I would assume the results of editing would follow suit of the other tests but can only assume without a test to run.
Past Sale Feedback
Amamba
Jun 24, 2013 10:59 |  #11
The way I read it, LR would take it's sweet time no matter what you try ;)
Ex-Canon shooter. Now Sony Nex.
Life Lessons: KISS. RTFM. Don't sweat the small stuff.
My Gear List (external link)
silvrr
Gallery: 13 photos
Jun 24, 2013 13:38 |  #12
Amamba wrote in post #16060177 (external link)
Here are some tests I did awhile ago. You can see that moving from the laptop to the current desktop things sped up considerably.
Looking at the results and tests I have done so far I wouldn't expect a whole lot of change. I'm trying to find my 5400 RPM drive to test that as I think it would slow it down considerably. The changes made represent incremental upgrades in performance and it often takes a leap in hardware updates to really 'feel' and see changes.
IMAGE: http://i111.photobucket.com/albums/n143/silvrr600/Capture-8_zpsb8dc009d.png
IMAGE LINK: http://s111.photobucke​t.com …re-8_zpsb8dc009d.png.html  (external link)
Past Sale Feedback
Geonerd
Jul 02, 2013 01:25 |  #13
Silvrr, can you please upload one of your RAW files so that we're all on the same page?
In the meantime, here's a RAW that could serve as a interim standard.
It's from a Drebel XT (8mp). https://dl.dropboxuser​content.com/u/60092457​/Raw/1.CR2 (external link)
Make a bunch of copies* - 50 is as good a number as any - and batch away!
(*With Windoze, you can right + drag = 'Copy Here' the file a short distance to an area within the same folder as the original. Now you have 2. Highlight and drag them to make 4, etc. The file names do become amusing: "Copy of copy of copy...." No idea how a Mac works, but there must be something similar. Right?)
This file is dead neutral, with no sharpening, NR, etc. assigned from DPP. The only different issue is the tungsten WB used to counteract the nasty light pollution.
FWIW, I'd be interested to see straight conversions using LR, DPP, and anything else, running on a variety of systems.
silvrr
Gallery: 13 photos
Jul 02, 2013 06:44 |  #14
Geonerd wrote in post #16082972 (external link)
It's 50 seperate files so uploading only one wouldn't give apples to apples. I have it on my list to try the tests with a few different sets of files to see how it effects the benchmarks. If its close (hoping it is) then anyone can use 50 RAW files of there own. I should have files for 10, 15 and 18 megapixels.
Past Sale Feedback
Geonerd
Jul 02, 2013 13:58 |  #15
silvrr wrote in post #16083352 (external link)
Cool. :)
15,087 views & 0 likes for this thread, 14 members have posted to it.
1360 guests, 178 members online
