Thread started 22 Jun 2013 (Saturday) 06:23
image in Office doc causing a problem
Lowner
"I'm the original idiot"
Jun 22, 2013 06:23 |  #1
I have an on-going document (Apache OpenOffice.org 3.4.1) where we record a photo and a few words on each car we have ever owned. I've finally got around to sorting out an sRGB jpeg image of roughly the right size but when I copy and paste it into the document it has this horrible red caste.
Any ideas about what's causing it? I don't see this anywhere else, just in the office doc.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/06/4/LQ_653734.jpg
Image hosted by forum (653734) © Lowner [SHARE LINK]
Richard
René ­ Damkot
Jun 22, 2013 07:31 |  #2
Looks like it's just the red channel, but I have no idea why…
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
lar55
Jun 22, 2013 18:50 |  #3
You can certainly do this if you want, but I can't see how it could happen without you knowing. Somewhere in Office are color adjustments for the inserted image. (In LibreOffice, it is on the Picture toolbar, Colors fly-out - not sure where it is in OpenOffice). If I select an inserted photo, then drop the Green and Blue amounts to "-100%", I get a picture that looks like that... so check the color settings for the inserted picture.
If it isn't that, I have no idea. Is there a color profile attached to the image?
Lowner
Jun 23, 2013 05:47 |  #4
Here is possibly what you mean. It pops up when the image is clicked on. However I've played with the channel percentages and while it changes, its hardly right.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/06/4/LQ_653809.jpg
Image hosted by forum (653809) © Lowner [SHARE LINK]
Richard
lar55
Jun 23, 2013 21:24 |  #5
If those are the settings when the picture looks all red, then no, that isn't the problem. (Except for the 8% brightness, those are the normal defaults.) Could there be a color profile attached to the image, perhaps in a format (like ICC v4) that OpenOffice doesn't understand?
Lowner
Jun 24, 2013 03:37 |  #6
lar55 wrote in post #16058669 (external link)
I've absolutely no idea. Its a bog standard sRGB JPEG produced from my aRGB TIFF original, at least that's what I thought I was doing!
Richard
lar55
Jun 24, 2013 21:35 |  #7
Upload the JPEG image somewhere and post a link, let people take a look at it?
Try converting again from your aRGB TIFF to JPEG, making sure the settings are what you want?
Paint the car red and use the picture as is?
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jun 24, 2013 23:10 |  #8
Did you try removing that image & then reloading it?
tzalman
Fatal attraction.
Jun 25, 2013 00:29 |  #9
This is not the reason for the red color, but as a side note, why Adobe RGB? Word processors are not color managed, of course - why would they be? - and the majority of readers will be using sRGB-like monitors.
Elie / אלי
pwm2
"Sorry for being a noob"
Jun 25, 2013 00:36 |  #10
tzalman wrote in post #16062250 (external link)
But the JPEG image isn't Adobe RGB. He did write:
Its a bog standard sRGB JPEG produced from my aRGB TIFF original,[...]
And it isn't the TIFF file that he inserts into the document.
Lowner
Jun 25, 2013 03:20 |  #11
Elie,
I routinely use Adobe RGB for my images, but this is not, its sRGB.
But maybe I'll redo another and dump this one, just to see if the second attempt gives the same result.
Richard
gewb
Gallery: 326 photos
Jun 25, 2013 14:20 |  #12
Hi Dick -
Covert to PNG and insert. Let us know if that helps. (I use LibreOffice which is similar.)
Regards,
GEWB
90D / 60D / Pro1 / A85
Lowner
Jun 26, 2013 13:34 |  #13
Panic over, but many thanks to you all for offering possible options.
I'm still in the dark about what caused it, but I reprocessed the JPEG and dumped the first attempt and second time around its fine, loaded into the document like a dream.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/06/4/LQ_654210.jpg
Image hosted by forum (654210) © Lowner [SHARE LINK]
Richard
2,740 views & 0 likes for this thread, 7 members have posted to it.
1099 guests, 120 members online
