Thread started 14 Apr 2001 (Saturday) 21:33
Floral macros
Del ­ K
Joined Apr 2001
Apr 14, 2001 21:33 |  #1
Taking advice to use RAW and get in closer, here is a study for your consideration. All taken in Clemson University President's Park, which is full of blooming azaleas, rhododendron, and dogwood. These are compressed jpg for quicker loading. First, sort of a standard photo with nothing special done, using program mode, ISO50.
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FOTOTIME
Moving in closer, the next is in program and macro mode and Tiffen 812 filter. These blooms are at the bottom left in the previous picture.
I wanted to blur out some of the background, so I added a 0.6ND filter to allow shooting at f/2.8; this is a little less than half the frame, the bloom on the right in the previous picture. A potential problem here is the amount of white-on-white. The upper right of the bloom would have the background blend right into the foreground if some in-camera control is not exercised, such as a ND to reduce depth of field.
Occasionally, we get an ordinary picture. The one below was back in program and macro mode with the 812, but the full shade resulted in a sort of flat tone. Instead of giving it a lot of PSP work as a photograph, I posterized it. Don't know how some of the purists might feel about posterizing. I don't do it routinely, but in this case, I think it made an interesting object out of an ordinary one.
Comments appreciated.
moonstone
Joined Apr 2001
Apr 15, 2001 08:51 |  #2
Nice picture Del.
Here are some photos (external link) that I have taken with my G1. Comments appreciated.
-Malcolm
Del ­ K
Joined Apr 2001
Apr 15, 2001 10:40 |  #3
Malcolm,
I like the colors, in both the petals and the greens in the foliage. If you are looking for suggestions, I have two:
1. I find the white background kind of stark. It does not distract, but some color in the background, for all but specialized shots, is usually a good idea.
2. The out of focus areas on the shot of the whole plant and the pot could be brought into focus. When the subject is a single or composite item with other stuff behind it, especially in macro shots, this is good. However, it appears that the whole plant is the subject, and so I would expect it all to be in focus. Might be difficult, not knowing your shooting conditions. You could try a shorter focal length, if possible. Or lower speed and smaller aperture.
moonstone
Joined Apr 2001
Apr 15, 2001 12:08 |  #4
Del,
Thanks for your suggestions :)
I agree with both your points. I used manual focus since autofocus did not seem to work well at close distance. However, I always find that trying to judge focus using the LCD is a difficult task.
-Malcolm
2,339 views & 0 likes for this thread, 2 members have posted to it.
Floral macros
1315 guests, 125 members online
