Thread started 23 Jun 2013 (Sunday) 10:54
Get the best out of rechargable batteries
jonneymendoza
Jun 23, 2013 10:54 |  #1
Hi i just bought a charger that charges aa and aaa batteries along with some Eneloop AA batteries that mean to be the best to get.
What are some of the tips to make batteries last longer?
i previously had some energizer ones and they were pretty much paper weight after only a years use if less.
any tips?
What is descharge mode on my charger? apparantly it has a descharge mode i can use? What for?
any tips on how to charge batteries etc?
Canon 5dmkIII | Canon 85L 1.2 | Sigma 35mm ART 1.4|Canon 16-35mm L 2.8 |Canon 24-70mm L f2.8 | Canon 70-200mm F2.8L MK2 | Canon 430EX MK2 Flickr (external link)
Naito
Jun 23, 2013 11:29 |  #2
Keep them cool. Heat is the enemy of electronics, batteries are no exception.
Use the slow charge mode if you have one, "conditioning" is generally unnecessary for NIMH batteries like the eneloops. Better to charge batteries slowly overnight than quickly in a 30min emergency.
Carl
EOS 40D | 6D
40mm f/2.8 STM | 50mm f/1.8 II | Tamron SP 70-300 f/4-5.6 Di VC | Opteka 500mm f/6.3 Mirror
Metz 50-AF1 | Yongnuo YN-622C
Echo63
Jun 23, 2013 13:18 as a reply to  @ Naito's post |  #3
the discharge mode on your charger will help to improve their life.
Nicad, Nimh and Low Self Discharge batteries can benefit from being fully discharged and recharged occasionally (i try and do it once a month, or every 5 charge cycles, whichever is longer)
also - dont run you batteries till they will no longer power the flash, change them out when you notice the recycle rate in your flash has slowed, overdischarging the batteries is one of the worst things you can do to them (your charger will discharge them to a safe level)
dont leave them flat in the bottom of your bag either, recharge them as soon as practical (a day or two is fine, a month will kill them
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
Wilt
Jun 23, 2013 13:45 |  #4
From greenbatteries.com
"When you intentionally discharge a battery down to a certain minimum voltage and then recharge it this is known as battery conditioning or reconditioning . It is also sometimes referred to as battery exercise. This is particularly important to reduce what some call the memory effect experienced using NiCD batteries if you habitually do not fully discharge them each time you use them. For NiCD batteries this must be done periodically, approximately every 10 charge/discharge cycles or so, or the batteries will begin to lose capacity. For NiMH batteries conditioning is not really needed to reduce any memory effect because that is negligible in this type of battery. However, reconditioning is very convenient for both NiMH and NiCD batteries because brand new batteries are not charged when you receive them and they must be charged and discharged three to five times before they reach their full capacity. "
Wilt
Jun 23, 2013 14:10 |  #5
NiMH should be charged in simple chargers at C/10 or below (10% of the rated capacity per hour).
If a temperature monitor is used NiMH batteries can be charged at rates up to 1C (in other words 100% of the battery capacity in amp-hours for 1.5 hours).
Russ61
Jun 23, 2013 23:50 |  #6
Wilt, interesting comment re the 1C. I've read elsewhere (lots of elsewheres) that others use the 0.5 charge and 0.25 discharge rates, ie 1/2 of rated capacity for charge rate and 1/4 for discharge. For Eneloops (AA's) that would equate to 1000 mA charge, 500 mA discharge. I'm trying to confirm with Sanyo re their Eneloops, but their own chargers do so at much lower rates, ie 250-300 mAh, for AA's. Further, I understand that slowest charge rates (ie 0.1C), often touted as best/safest, are suggested by some to run the risk of overshooting their rated capacity as the slow rate doesn't trigger the "shut off" mechnaism. I also think that some of the advice given by users might be predicated on technology for NiCd or even standard NiMH and not necessarily applicable for LSD NiMH (Eneloops et al). Thoughts?
jonneymendoza
Jun 24, 2013 00:58 |  #7
This is the charger i purchased.
http://www.maplin.co.u​k …r-with-lcd-display-105064 (external link)
any good
Naito
Jun 24, 2013 07:22 |  #8
jonneymendoza wrote in post #16059157 (external link)
any good
As has been said here, fast charging is the WORST thing you can do to nimh batteries. It significantly shortens their life by overheating.
Carl
EOS 40D | 6D
Wilt
Jun 24, 2013 10:48 |  #9
Russ61 wrote in post #16059079 (external link)
The information which I previously posted was a simplification of what is very complex 'best practice' charging and monitoring of state of charge completion. For example, the c/10 chargers can overcharge batteries if they are only slightly discharged. The information was excerpted from
http://www.powerstream​.com/NiMH.htm (external link)
Panasonic also lists 1C for rapid charge rate
http://www.panasonic.c​om …ic_NiMH_ChargeM​ethods.pdf (external link)
Refill
Joined Jan 2013
Jun 24, 2013 11:08 |  #10
Many chargers just test if the batteries are fully charged. If not, they do a full charging cycle, not adjusting to the real discharge level. So if your NiMH batteries are 10% or 80% charged, they will just get the same full load (and overload). Use the discharge function with your NiMH batteries, at least if they don't overheat during discharge, because I think overheating is one of the reason it is better not to overcharge!
LiPos are different, I believe it's better not to fully discharge them. You can also charge them at 40% and put them in the fridge (seriously) if you don't use them for a long time.
jonneymendoza
Jun 24, 2013 16:12 |  #11
Naito wrote in post #16059615 (external link)
well its too late for now as thats the one i can use
pwm2
"Sorry for being a noob"
Jun 24, 2013 16:54 |  #12
That is the main goal with 0.1C - the temperature is so low that the batteries doesn't get hurt by dumb chargers that typically take 14 hours timer-controlled with zero other sensors. No voltage or temp sensor needed.
Naito
Jun 24, 2013 18:06 |  #13
jonneymendoza wrote in post #16061083 (external link)
Then don't be surprised if your new batteries also die within a year :lol:
Carl
EOS 40D | 6D
ElectronGuru
Jun 24, 2013 22:23 |  #14
You can get the best charger available (see here (external link)) but you've already done the most important thing: getting eneloops. They rarely die, even after years of solid abuse.
"Light is the paint, lenses are brush, sensors are the canvas"
6D | 100L Macro | 50L | 24L TSE
Builder of custom flashlights, OVEREADY.com (external link)
Echo63
Jun 25, 2013 00:21 |  #15
ElectronGuru wrote in post #16061991 (external link)
Hi ElectronGuru !
Didnt realise you were a member here too (im also a member on CPF)
I suppose it shouldnt be surprising with the nice product pics on your site, that you would have an intrest in photography
5,646 views & 0 likes for this thread, 13 members have posted to it.
1461 guests, 136 members online
