Thread started 25 Jun 2013 (Tuesday) 17:35
Baby Chloe
deanbayley
Joined Jun 2013
Jun 25, 2013 17:35 |  #1
IMAGE: https://dl.dropboxusercontent.com/u/3203305/chloe1.jpg
IMAGE: https://dl.dropboxusercontent.com/u/3203305/chloe2.jpg
Gripped Canon 60D | EF 50mm f/1.4 USM | EF-S 17-55mm f/2.8 IS USM | EF 70-200mm f/2.8 L IS II | EF 2x III Extender | 600EX-RT
Gripped Fuji XT-1, 18-55mm f/2.8-4 OIS, 55-200mm f/3.5-4.8 OIS, 35mm f/1.4
iadubber
Jun 27, 2013 07:22 |  #2
one is way OOF
two seems OOF as well.
I can't read any EXIF data from your images. What lens were you using? Two needs deeper DOF to get the face in focus.
Buyer/Seller Feedback
deanbayley
Joined Jun 2013
Jun 27, 2013 16:17 as a reply to  @ iadubber's post |  #3
Canon EF 50mm f/1.4..
mike_d
Jun 27, 2013 16:30 |  #4
Shutter speed and aperture? I'm guessing you're trying to use ambient light and struggling to get a proper exposure, leading to a wide open aperture and a slow shutter speed. Ambient light can be great, but its often not enough indoors so I use bounced flash a lot. Just wait until she really starts moving.
I use my 50/1.4 a lot but rarely larger than f/2. You'll need to stop down quite bit to get both eyes in focus if you're near the minimum focusing distance and her eyes aren't the same distance from the camera as in the second shot.
deanbayley
Joined Jun 2013
Jun 27, 2013 16:55 as a reply to  @ mike_d's post |  #5
See Attached
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/06/4/LQ_654380.jpg
Image hosted by forum (654380) © deanbayley [SHARE LINK]
mike_d
Jun 27, 2013 17:04 |  #6
Stop the lens down for more depth of field. I'd use a faster shutter speed too. 1/60 is OK if she doesn't move, but you'll quickly get motion blur when she moves, especially in the hands which can move quickly. Raise the ISO to compensate for the smaller aperture and faster shutter.
deanbayley
Joined Jun 2013
Jun 27, 2013 17:09 as a reply to  @ mike_d's post |  #7
I don't have a separate flash and with her being a baby obviously wouldn't use the popup flash so close to her, which flash would you recommend?
Also whats the maximum ISO you would recommend?
Thanks..
Dean.
mike_d
Jun 27, 2013 17:15 |  #8
deanbayley wrote in post #16070859 (external link)
Thanks..
Dean.
I have a 580EXII flash but anything that you can aim the head at the wall or ceiling will do the job. There's a number of non-Canon units like Yong Nuo that are a lot cheaper. ETTL units are more expensive than full manual ones, but easier to use.
As for ISO, I'd use whatever I needed to get the exposure I needed. High ISO noise doesn't show up too much on web sized images or small prints. High ISO noise can be addressed in post processing but if you get a shot with insufficient DOF or motion blur from a slow shutter, you're stuck with it. Some of my favorite shots of my kid are at ISO3200 which is my 5D's max.
deanbayley
Joined Jun 2013
Jun 27, 2013 17:40 |  #9
Procamerashop have the 600ex at £350, could be a plan :D
mike_d
Jun 27, 2013 17:44 |  #10
deanbayley wrote in post #16070938 (external link)
Getting a speedlite and learning how to use it opens up a whole new world. Go for it. She'll only be this age once.
iadubber
Jun 28, 2013 10:24 |  #11
You can find a cheap used 430EX II that should be great to get you started in the world of bounce flash. You should also check out http://www.dofmaster.c​om/dofjs.html (external link) and learn about depth of field.
I'm assuming you were pretty close to here so I guessed 3 feet away. That gives you not even 3/4" that would be in focus had you nailed the focus point. Once you stop down the aperture or get a little more distance from the subject the DOF gets deeper.
Subject distance 36 in
Depth of field
Near limit 35.7 in
Far limit 36.3 in
Total 0.67 in
In front of subject 0.33 in (50%)
Behind subject 0.34 in (50%)
Hyperfocal distance 3665 in
Circle of confusion 0.019 mm
ktan7
Joined Mar 2013
Jun 28, 2013 11:11 |  #12
Great shot but your pictures are out of focus.
Vancouver wedding photography (external link)
Picture blog (external link)
Mexico wedding photographer (external link)
deanbayley
Joined Jun 2013
Jun 29, 2013 10:26 as a reply to  @ ktan7's post |  #13
My Dad lent me a 600EX to have a play with, a lot more options than i thought..
Took some shots with the flash bounced off the ceiling, what a huge difference.
Ordered a 600EX from procamerashop..
Thanks guys..
Dean.
1,945 views & 0 likes for this thread, 4 members have posted to it.
Baby Chloe
1455 guests, 148 members online
