Thread started 25 Jun 2013 (Tuesday) 17:38
What are you guys doing in post processing?
Frodge
Joined Nov 2012
Jun 25, 2013 17:38 |  #1
I have Lightroom 4. Lets say you take a couple hundred photos, when you import them into your post processing program, what are the most common changes that you make to the photo before you present it to the world? I'm trying to understand what changes you guys and girls are making to the majority of your pictures.
As an aside, can you move folders with pictures you have already imported into lightroom? As an example if you have a folder full of pictures on your desktop that was imported into lR, can you then move it to another location? Or will it screw the database up. How do you move folders?
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jun 25, 2013 19:38 |  #2
Last first...
Moving it outside Lightroom will cause problems as it will lose track of the images. They will then show in LR with a ? error. For this reason it is better to move the folder within LR if possible. In the Library module go to the Folders pane, click/hold the folder you want to move and drag it to the new location.
Unfortunately LR is a little odd. I can't find a way to (for example) move a folder or image to a second drive that I have not already imported images from. In this situation you just move the folder outside of LR then go back to LR, right click on the folder and select Update Folder Location.
Frodge wrote in post #16064634 (external link)
I most commonly make changes to the White Balance, Exposure, Highlights, Shadows, Whites and Blacks, Clarity, Sharpness and (in the case of higher iso) NR.
Dan Marchant
Frodge
Joined Nov 2012
Jun 25, 2013 20:00 |  #3
Thanks Mr. Marchant. So if I have a folder on my desktop that I have made changes to already, it is impossible to move that folder to let's say, the "pictures" folder without losing what I had already edited?
fashionrider
Joined Dec 2011
Jun 25, 2013 20:16 |  #4
Example, if I shoot a graduation party inside a building, and there's also the outdoor area, I honestly leave the WB on my camera the same throughout the day. Normally I'll see the WB for the outdoor shots, then when I go inside, the shots tend to look more orange or blue, but I leave it, because it can fixed easily in LR. Once I import all of them into LR, I select a single photo taken indoors, and fix the WB. Then I select the rest of the indoor shots and sync the WB. Done, and it took about 30 seconds to do them all. If you notice all your indoor shots are almost all equally overexposed, adjust one, then sync the rest. It's all about sync'ing settings to similar images. After all that, then you can go thru each image and adjust whatever you want
Gear List (5D3, 70-200 f2.8L IS II, Sigma 85mm f1.4, Sigma 35mm f1.4, 50 f1.8, 24-105L, Alien Bee lights, etc etc)
Frodge
Joined Nov 2012
Jun 25, 2013 20:28 |  #5
Another great tip. I was just wondering the basic changes everyone makes. It seems you have a ton of tools to use. It can be a bit overwhelming.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jun 26, 2013 01:59 |  #6
Frodge wrote in post #16064932 (external link)
I listed two ways to move it in my post above.
Dan Marchant
Frodge
Joined Nov 2012
Jun 26, 2013 06:11 |  #7
So I'm assuming if you move within lightroom, it moves it physically on the HDD as well? Or if you move the folder and update in lightroom, it keeps your changes to he photos?
PixelMagic
Jun 26, 2013 06:24 |  #8
You can move a folder of photos either from within Lightroom or using your operating system's file manager (Finder of Windows Explorer). However it is not advisable to use the OS File Manager unless you know how to tell Lightroom's database the new location of the files.
To move files from within Lightroom
1. Go to the Folders panel on the left side of the Library Module. Use the arrow heads to expand the drive/folder locations to find the specific folder you want to move.
2. Click on the folder to select it, then drag and drop it to the new location.
If you're moving the folder to a DRIVE that isn't currently listed in the Folders panel, you need to use the (+) sign on the right of the Folders panel header to Add a Folder then drop the selected folder there.
RandMan
Joined Mar 2012
Jun 26, 2013 07:52 |  #9
Personally, I don't think that question can be answered if you don't specify whether you are shooting RAW or jpg's. I only shoot RAW, so all my photos are imported with one of my own presets I created that will apply a little contrast, vibrance, positive or negative clarity, sharpening, lens correction, color profile and a couple of others. Those that shoot jpg may respond to your question by saying, "Nothing!"
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
carguy4471
Joined Sep 2009
Jun 26, 2013 08:26 |  #10
RandMan wrote in post #16066090 (external link)
This is what I did. Created an import profile to add clarity, vibrance, saturation in the values I land at most. 25, 20, 5 respectively. I can tweak them a little during post if needed but that's a good starting point. Once the photos are imported with those adjustments I add my camera color profile, lens correction, and fix white balance on the first photo off a capture of a color checker passport. Then sync this to the remaining photos. If it's a similar scene to a camera profile I already have I simply use that one instead of creating a new one.
These are the changes that get made to every photo immediately, takes 2 minutes at best. Then I scroll through and mark for delete any missed focus/poor photos. Once that's done I scroll through and do the cropping, developing on each photo.
Duane
GEAR - FLICKr (external link) - SmugMug (external link):p
RandMan
Joined Mar 2012
Jun 26, 2013 09:15 |  #11
carguy4471 wrote in post #16066163 (external link)
Awesome trick if you didn't know--set the first lens correction dropdown to "Auto" and then update your input profile to include that setting. With auto selected, it will always choose the lens used regardless of what is being displayed when you initially save the setting. Then you don't have to tick "Enable Lens Correction" every single time.
PixelMagic
Jun 26, 2013 09:40 |  #12
I used an X-Rite ColorChecker Passport to create Dual Illuminant profiles for all my cameras. In fact I created two versions of each DI profile using the X-Rite software and Adobe's DNG Profile Editor. Those profiles are set as the defaults in Lightroom and ACR and since each camera's sensor is custom profiled, I get accurate renditions when raw files are imported and I've never had the need to use Import presets of any kind.
carguy4471
Joined Sep 2009
Jun 26, 2013 10:48 |  #13
RandMan wrote in post #16066284 (external link)
That's a killer trick, thank you!!
Duane
Frodge
Joined Nov 2012
Jun 26, 2013 12:11 |  #14
What does lens correction actually do?
carguy4471
Joined Sep 2009
Jun 26, 2013 12:28 |  #15
Frodge wrote in post #16066831 (external link)
It will correct for distortion and vignetting.
Duane
2,403 views & 0 likes for this thread, 10 members have posted to it.
2233 guests, 127 members online
