Thread started 26 Jun 2013 (Wednesday) 08:55
1d mark 2 autofofus question
jaomul
Joined Apr 2011
Jun 26, 2013 08:55 |  #1
Sometimes when I focus in one shot mode using centre point half press and recompose, the camera seems to lose focus and wont shoot. Is there something I am missing. It does seem to hapoen in low contrast areas such as when I focus on a boat and then move the camera so the centre point is over the sea for example. Has anyone any ideas of what I am doing/not doing or has my camera a problem. Thanks
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
rrblint
Gallery: 84 photos
Joined May 2012
Jun 26, 2013 09:02 |  #2
Does the focus confirmation indicator light steadily(not blinking) before you recompose? Does it beep(if enabled)?
Mark
cdifoto
Don't get pissy with me
Jun 26, 2013 09:05 |  #3
Personal Function 14 is probably set to disable focus searching.
jaomul
Joined Apr 2011
Jun 26, 2013 09:11 |  #4
I never have the beep on but will in future. Personal function 14 is set to disable. Unfortunately I dont have driver discs for this. Now begins my search for these. Thanks for the quick replies
cdifoto
Jun 26, 2013 09:34 |  #5
jaomul wrote in post #16066278 (external link)
Hmm. Perhaps your technique is bad. If you do the focus-recompose dance you need to make sure you stay half-pressed on that button. Also keep in mind that it doesn't work in AI Servo. Mark IIs also have fairly spongey buttons so I usually choose my focus point instead.
jaomul
Joined Apr 2011
Jun 26, 2013 10:22 |  #6
cdifoto wrote in post #16066343 (external link)
You could be correct. I never had this trouble before though with any other camera. I will enabke the beep to be sure and try hunt down sone siftware to change the personal setting. Thanks again
cdifoto
Jun 26, 2013 10:28 |  #7
jaomul wrote in post #16066484 (external link)
I didn't really either. Even my 30D had a more defined half-press. The 1D II portrait button is so mushy I don't even have it enabled.
872 views & 0 likes for this thread, 3 members have posted to it.
911 guests, 118 members online
