Hey guys
I have a few things which makes me think, when it comes to logical thoughts on lenses etc.
If i have a 50mm 1.4 lens on FF, will it give me the same depth of field like a 100mm 2.0 lens on FF?
My thesis: as focal length is a factor for the DOF, it would be logical when you double the amount of light coming through the lens, you would need half the focal length required to get the same DOF and bokeh (despite that every lens renders it different)
Is that true?
Then, why does fullframe sensors offer a better isolation with the same lens on crop? Cause, lets say you have a 50mm 1.4 lens: On FF thats effective 50mm FOV with great isolation at 1.4. If you put it on a crop sensor, the FOV becomes something around 80mm equivalent on FF. So the DOF and isolation is more as the same lens at same aperture. So if crop sensors has less DOF than same lenses on FF, it should be almost the same. But why isnt it like that?
