Thread started 28 Jun 2013 (Friday) 14:10
How to achieve this effect in post-processing
Mister ­ Fortune
Joined Jun 2013
Jun 28, 2013 14:10 |  #1
Title :)
Wondering how to process an image like this... Thanks in advance :)
eclivic
Jun 28, 2013 14:16 |  #2
Lower contrast and use minor split toning
600D/ML Gripped | 18-55mm IS | 70-300mm IS | 10-18mm IS STM | 50mm 1.8 | YN-560 |
Mister ­ Fortune
Joined Jun 2013
Jun 28, 2013 14:44 |  #3
eclivic wrote in post #16073472 (external link)
Thanks!
What kind of split toning should I use here? I tried something with brown, but this picture seems to have some kind of "metallic" effect, I cannot find out what is that exactly...
eclivic
Jun 28, 2013 14:46 as a reply to  @ Mister Fortune's post |  #4
what are you using, I would assume lightroom?
Mister ­ Fortune
Joined Jun 2013
Jun 28, 2013 14:51 |  #5
eclivic wrote in post #16073559 (external link)
Lightroom 4 and Photoshop CS6 available :)
eclivic
Jun 28, 2013 14:52 as a reply to  @ Mister Fortune's post |  #6
Could you post the image your trying to change. I'd also be more then happy to take a stab at it if you have the raw file and then send you the exported settings.
René ­ Damkot
Jun 28, 2013 15:33 |  #7
Also, if an image isn't yours (which I'm assuming, since you're asking how to do it), you can only post a link to it…
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Mister ­ Fortune
Joined Jun 2013
Jun 28, 2013 15:41 as a reply to  @ René Damkot's post |  #8
Oh, if you ask for a link for image I posted in opening post, I do not have a link, I have it only offline ATM
I do not need particular image post-processed, I would like to somehow learn how to consistently output such style :)
Thanks guys
eclivic
Jun 28, 2013 15:47 as a reply to  @ Mister Fortune's post |  #9
In a nutshell, It is just Split toning, Lower contrast, Individual Color Saturation lowered, Lights Raised and Shadows Raised.
PixelMagic
Jun 28, 2013 16:55 |  #10
As already pointed out the effect is obtained by split toning and can be achieved through the Split Toning panel in Adobe Camera Raw or Lightroom or Curves adjustment.
In this specific photo the effect is a function of lighting and split toning. Just by observing the hard shadows cast on the bride's chest and on the wall behind her there's a strong likelihood that the photographer used a bare, unmodified flash positioned above the groom(judging by the shadow of the groom's nose) and to the left of the camera (notice his body casts a shadow on the bride).
You can also use Color Samplers at the white, grey, and black points to understand how the Curves were manipulated to achieve the effect.
IMAGE: http://i.imgur.com/VB4djzw.jpg
Based on the sampler points you can see that all three RGB channels were lowered at the white point and raised at the black point. The blue channel was most adjusted at both ends and notice the grey point sampler shows elevated blues in the midtones. The Reds are also elevated in the shadow areas.
This pertains to this image alone and shows the technique used to adjust it but you really can't make generalized conclusions that this specific approach works on all images; it always depends on the content of an image.
Mister ­ Fortune
Joined Jun 2013
Jun 29, 2013 15:04 as a reply to  @ PixelMagic's post |  #11
Thank you very much PixelMagic.
Nice hints, I know where to go now, I will try something using your advice in curves/levels :)
TridenTBoy
Joined May 2011
Jun 29, 2013 19:15 |  #12
What was the image? I am interested from what PixelMagic posted.
1,490 views & 0 likes for this thread, 5 members have posted to it.
2246 guests, 128 members online
