Thread started 01 Jul 2013 (Monday) 15:58
60D Live View exposure anomaly
ettlz
Jul 01, 2013 15:58 |  #1
Just yesterday I noticed that stills taken with Live View were coming out around 1-2 stops darker than those taken using the usual, optical viewfinder with high shutter speeds (1/3200s or faster). This isn't a metering issue: I had the camera in full manual mode -- same shutter, aperture and fixed ISO, only the Live View ones came out darker.
My first feeling was that this could be impending shutter failure, but if that were the case I'd expect to see the underexposure with shots taken using the optical viewfinder too. But those have all turned out spot-on. This strange behaviour was quite consistent -- underexposed only when taken using Live View at faster shutter speeds. I also tried with the camera in high-speed continuous shooting mode, and got the same difference in exposure.
There is some evidence, looking at the depth-of-field in some of the darker shots, that the camera was taking it upon itself to stop down a bit (although that isn't certain). Can't see any marked differences in noise, so I don't think it's a random change of ISO.
This happened with all my lenses. Oddly, this first started after I acquired a Sigma 17-50 f/2.8 OS lens, although this may be coincidence. I decoupled the lens, removed the battery, and left the camera overnight. It's now back to normal. The only thing I can think of is that something got seriously confused in the camera's software and is now reset.
Anyone else seen anything like this?
Canon EOS 60D :: Canon EOS 7D :: Canon EOS 10 :: Canon EF-S 18-55mm f/3.5-5.6 IS STM :: Manual-focus Canon EF 50mm f/1.4 USM :: Canon EF-S 55-250mm f/4-5.6 IS STM
boerewors
Joined Sep 2009
Jul 01, 2013 18:09 |  #2
What i know is that when a camera is in live view it will adjust the aperture to save your sensor from being fried by ambient light whereas normal viewfinder viewing is always wide open aperture. So somewhere along the line your camera must have been getting confused. Were you outdoors when it happened? Well if you said it went away after resetting the camera, i wouldnt worry too much unless the problem regularly repeats its self. Weird things often happen to cameras.
The most important piece of gear you own, resides in your head and its called your brain.
kenshap
Jul 01, 2013 18:35 |  #3
Did you cover the viewfinder in live view with the eyepiece cover? I think I remember reading the viewfinder has to be covered to prevent confusing the sensor.
Canon T6s (battery grip) | Canon T4i (aftermarket battery grip) | Canon T2i | Canon EF-S 18-55 IS | Canon EF-S 55 - 250 | Canon EF 50mm f/1.4 | Canon EF-S 10-22mm | Canon EF 100mm f2.8L Macro | Canon 40mm
John ­ from ­ PA
Joined May 2003
Jul 01, 2013 19:37 |  #4
If you followed the instruction its that black rubber gadget you mounted on the neck strap. Page 124 of the manual.
oldvultureface
Gallery: 85 photos
Jul 01, 2013 22:32 |  #5
kenshap wrote in post #16082000 (external link)
John from PA wrote in post #16082168 (external link)
As an aside, live view does not require the viewfinder to be covered. Exposure is set using only evaluative metering on the sensor itself. When using the viewfinder, exposure is read from the focusing screen. That's when extraneous light entering the viewfinder can affect exposure.
ettlz
Jul 02, 2013 00:52 |  #6
That shouldn't make any difference when in 'M' mode. No form of camera metering is being used to control the exposure.
hollis_f
Jul 02, 2013 03:58 |  #7
Examples with full exif?
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
ettlz
Jul 02, 2013 12:36 |  #8
hollis_f wrote in post #16083136 (external link)
It's behaving normally at the moment, and I scrubbed all the old ones. Will post as soon as this happens again and I can take controlled shots... there may well be something interesting lurking in the EXIF. All I can add right now is that it'll be two shots of the same scene, with the same light and exactly the same shooting settings -- but the Live View one will be darker.
[Comment about slightly uneven exposure in Live View removed: had Silent Shooting on, known phenomenon...]
1,693 views & 0 likes for this thread, 6 members have posted to it.
1050 guests, 111 members online
