So I'm new to astrophotography. I have a Celestron SCT 9.25" scope, and a Canon 7D (and/or 50D). I have the Canon T-adapter and T-Ring which fits good and snug, and looks much like this picture: http://www.88qv.com/net/lens.jpg
(note: not my pic, just one I found posted here). I also have the Canon camera (either 50D or 7D) hooked up via USB cable to my laptop and using the EOS Utility to capture images without touching the camera.
The major problem: I am only getting black images, regardless of how or what I take pictures of. At times I did get a sort of white halo (which looked a lot like taking the Star Diagonal off the scope and looking directly into the tube at a bright object). Regardless, I am at a loss for why I'm getting zero results. Right now is a perfect night and I'm out in the middle of nowhere, perfect for taking images, but I can't take any since it's not producing anything but blackness. I have also tried using the Live View feature of the EOS Utility which also produces an all-black view. I have further troubleshot this by pointing it directly on Saturn (and anticipating it being in center view while I adjust it for the camera), and still getting all black images. I have also tried using the Barlow 2x magnifier lens between the scope and the camera using one of the T-adapters (I have 2) - same thing. Any help on this would be EXTREMELY appreciated. Also, I have both a Celestron T-Adapter (93633-A - http://www.amazon.com …-Telescopes/dp/B00009X3V8
) for Canon, as well as the Celestron T-Adapter 93625 (http://www.amazon.com/camera-photo/dp/B0000665V6
), and the Canon T-Ring which works for both adapters. Both hook up in different ways to the telescope, but both produce the black images. Unfortunately in the past few nights I have been testing the adapters, the moon hasn't been out (easiest target to test on, I would assume).
EDIT: And it doesn't appear to be anything blatantly obvious, such as having the scope's lens cover on (since I am able to view through the regular scope lens without camera just fine).
Again, any help would be greatly appreciated - I've spent way too much money on this equipment just to not be able to use it correctly.
Thanks!
