Thread started 02 Jul 2013 (Tuesday) 13:53
RF-603C hotshoe lock
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Jul 02, 2013 13:53 |  #1
anyone know if a way to lock this sucker on the camera. I've seen the "tie wrap" idea and will do that if thats the only option left.
So far I like em just not the fact it falls off easy.
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
sjwolfhope
Joined Oct 2011
Jul 02, 2013 19:38 |  #2
Take a look at this thread:
https://photography-on-the.net …/showthread.php​?t=1142694
Uses easy to find "O" rings. Bought two sizes at Home Depot - #41 and #9. Works like a charm. Put the thicker one (#9) against the trigger body and the thinner one (#41) against the metal hotshoe. You will have a lifetime supply of "O" rings.
Steve W.
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Jul 02, 2013 20:38 |  #3
Brilliant. Thank you Steve!
My Gear Archive
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Jul 04, 2013 07:48 |  #4
#9 on top and #41 on bottom = rock solid. Thanks man.
My Gear Archive
sjwolfhope
Joined Oct 2011
Jul 05, 2013 16:36 as a reply to  @ Talley's post |  #5
Glad it worked for you as well as it does for me. Well done to seoul4korea who did the original work on this. Not sure how often they might need replaced - just keep an eye on them for any tears in the "O" ring rubber.
Steve W.
BrickR
Joined Mar 2011
Jul 05, 2013 19:02 |  #6
I just use rubber bands. Office Max size 16 wrapped around the foot a few times and that sucker is on tight.
My junk
The grass isn't greener on the other side, it's green where you water it.
sjwolfhope
Joined Oct 2011
Jul 05, 2013 20:38 |  #7
BrickR wrote in post #16094865 (external link)
I tried rubber bands before buying the "O" rings. "O" rings seem to work so much better and aren't really that expensive.
Steve W.
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Jul 05, 2013 20:38 |  #8
sjwolfhope wrote in post #16094538 (external link)
Steve W.
Was like 4 bucks for a pack of 20 each. I have plenty and I tell you want I can literally hold the trigger by itself and shake the crap out of the camera and it doesn't budge. Stronger then the canon flash lock on my 430exII I swear.
My Gear Archive
waterrockets
Joined Jun 2010
Jul 07, 2013 21:23 |  #9
I've been doing great with a couple of my daughter's 1" diameter elastic bungee-style rubber bands for her hair. They aren't as high friction as a regular rubber band, and two loops around the shoe allows for easy install and a good secure fit. I just haven't taken the time to head out to my shop to dig through my o rings yet.
1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
965 views & 0 likes for this thread, 4 members have posted to it.
2293 guests, 132 members online
