Hi there - just picked up a very reasonably priced Siggy 300/2.8 prime I've been eyeing up for a few months now. Handling the lens now, I've realised a couple of things that were previously unknown-unknowns. Hopefully some owners or previous owners may be able to help.
1) 46mm CPL; Is it a bog standard 46mm CPL? Does the bezel thickness play a part in compatibility? The Hoya 46mm CPL would be my first choice having used them before, but currently it seems that the seller fitted a UV filter instead. Maybe that's just a placeholder - I know the new item ships with a CPL, does it also ship with a UV? Should it ever be used empty? Also, it was my understanding that CPLs required light at 90deg to the plane of filter to perform most effectively - without light making direct contact at the front element, is this type of rear-installed filter less effective than in other applications?
2) TC recommendation; I've seen great examples with the 1.4x and 2x, and it seems that Sigma DG TCs are the way to go for this lens - however, I wanted to ask directly - has anyone ever stacked 1.4s instead? In the lens gallery for this optic there's a guy using it at '840mm' which is 300 x 2.8. Still only 2 stops aperture loss? Are Canon's latest v3 TCs better than Sigma's (with this lens)?
3) Front lens cap; As a new owner of big glass, I'm content with the supplied hood and fabric 'helmet' for the front element, but I don't know whether there's a traditional plastic pinch lens cap missing or not - anyone know? A recommendation on a carry case would also be useful as mine came in bubble wrap.
4) Monopod recommendation, quick release shoe design recommendation; I bought this lens with the intention of getting into more wildlife and nature photography - having handled it yesterday evening, round the neck support is a non-starter, nor is carrying in arms long term if I want the strength to hold it steady. I don't want to have to carry a tripod everywhere, so a monopod is the only sensible option - there are tens of the things - would anyone mind making a recommendation for holding up the Siggy with a 2xTC and 5Dc? I've also seen this 'bean bag' mentioned as a support method - is it only when resting on the ground? or simply to find a hard spot on location and perch the camera on it? I also just changed by landscape setup from Manfrotto's RC2 to the larger RC4 when I changed head and I notice it's far more robust and stiffer. I've never owned a lens with a tripod mount on it, so I'd find it useful to know I was buying a solid shoe/head for the pod.
Much to read, much to answer, hopefully there are some keen gearheads who've got the answers! Thanks in advance!
