I was considering this lens at 500mm it is 6.3 will my 7D AF on this it is only good to 5.6
My guess is AF would be slow.
BlackBart Member 241 posts Likes: 15 Joined Aug 2009 More info | Jul 04, 2013 09:55 | #1 I was considering this lens at 500mm it is 6.3 will my 7D AF on this it is only good to 5.6
fishyone Senior Member 465 posts Likes: 6 Joined Oct 2005 Location: Iowa More info | Jul 04, 2013 11:05 | #2 Yes your 7D will AF with this lens. I've been using it on a 20D and 40D for years with no problems. I've been able to capture hummingbirds in flight so AF can't be too bad. www.creationspraise.zenfolio.com/
Jul 04, 2013 11:12 | #3 fishyone wrote in post #16090764 Yes your 7D will AF with this lens. I've been using it on a 20D and 40D for years with no problems. I've been able to capture hummingbirds in flight so AF can't be too bad. Thanks for the reply I can pick up one of these cheap I may try one.
fishyone Senior Member 465 posts Likes: 6 Joined Oct 2005 Location: Iowa More info | Jul 04, 2013 11:30 | #4 |
fishyone Senior Member 465 posts Likes: 6 Joined Oct 2005 Location: Iowa More info | Jul 04, 2013 11:35 | #5 Here's one of my hummer shots taken with a 20D. and one using the 1DIII www.creationspraise.zenfolio.com/
Snydremark my very own Lightrules moment More info | Jul 04, 2013 11:45 | #6 Yep; it'll AF just fine. The cutoff for AF on the Canon bodies is f/8, so it doesn't get cut off. - Eric S.: My Birds/Wildlife
aphphoto Senior Member 455 posts Likes: 52 Joined Nov 2010 More info | I have the older generation 50-500 without image stabilization. Good results on a 30D. I also have the 2x extender but never use it as it really requires a tripod in my experience and that just doesn't work in motorsports which is my main interest. who gives a rat crap how much gear you can list?
Jul 04, 2013 12:37 | #8 fishyone wrote in post #16090854 Here's one of my hummer shots taken with a 20D. ![]() and one using the 1DIII ![]() Looks nice I have a 1D mkIII but I usually keep it on my 600L.
CyberDyneSystems Admin (type T-2000) More info | Jul 04, 2013 13:08 | #9 Snydremark wrote in post #16090873 Yep; it'll AF just fine. The cutoff for AF on the Canon bodies is f/8, so it doesn't get cut off. This is inaccurate, most canon Bodies will not AF past f/5.6 GEAR LIST
Jul 04, 2013 13:47 | #10 CyberDyneSystems wrote in post #16091103 This is inaccurate, most canon Bodies will not AF past f/5.6 The reason the SIGMA works with ALL Canon bodies, including the majority that can not AF past/8, is it tells the Camera AF that it is actually f/5.6 (it lies )This coupled with the lens specific design allows the lens to function as if it were an f/5.6 at the long end. This has no effect on exposure, which is based on actual light the meter reads, with no bearing on what the lens aperture claims it is set to. Then why the hell don't canon do this.
tomj Senior Member 706 posts Likes: 61 Joined May 2010 More info | Jul 04, 2013 18:01 | #11 "The reason the SIGMA works with ALL Canon bodies, including the majority that can not AF past/8, is it tells the Camera AF that it is actually f/5.6 (it lies )
Snydremark my very own Lightrules moment More info | Jul 04, 2013 19:49 | #12 CyberDyneSystems wrote in post #16091103 This is inaccurate, most canon Bodies will not AF past f/5.6 The reason the SIGMA works with ALL Canon bodies, including the majority that can not AF past/8, is it tells the Camera AF that it is actually f/5.6 (it lies )This coupled with the lens specific design allows the lens to function as if it were an f/5.6 at the long end. This has no effect on exposure, which is based on actual light the meter reads, with no bearing on what the lens aperture claims it is set to. Do you have a source on that? I've always, actually, been curious to know whether the logic is "above f/5.6" or "f/8 and above", but I've never seen any documentation; I just figured it was "f/8 and above" in order to not mess with oddballs like the Sigma, or the Tamron 18-270, etc. - Eric S.: My Birds/Wildlife
BeachcomberJoe Senior Member 466 posts Likes: 3 Joined Jan 2010 Location: Southwest Florida More info | Jul 04, 2013 22:34 | #13 CyberDyneSystems wrote in post #16091103 The reason the SIGMA works with ALL Canon bodies, including the majority that can not AF past/8, is it tells the Camera AF that it is actually f/5.6 (it lies )This coupled with the lens specific design allows the lens to function as if it were an f/5.6 at the long end. I have the 150-500. When racked all the way out and aperture wide open my camera bodies (6D, 7D & T3i) indicate f/6.3. I find it hard to believe that the lens is telling the camera that it is both an f/5.6 lens and that it is stopped down to f/6.3. The more reasonable assumption in my mind is that Canon does not have a hard f/5.6 shut off but allows f/6.3 and possibly more in their bodies.
Jul 05, 2013 10:55 | #14 Beachcomber Joe wrote in post #16092422 I have the 150-500. When racked all the way out and aperture wide open my camera bodies (6D, 7D & T3i) indicate f/6.3. I find it hard to believe that the lens is telling the camera that it is both an f/5.6 lens and that it is stopped down to f/6.3. The more reasonable assumption in my mind is that Canon does not have a hard f/5.6 shut off but allows f/6.3 and possibly more in their bodies. In answer to the OP, my 150-500 focuses fast and accurately with my 7D body. The 50-500 OS is very similar so I would expect the same results. I believe you are right I tried a canon 1.4 TC on my 100-400 and my 7D tried to auto focus.
JeffreyG "my bits and pieces are all hard" More info | Jul 05, 2013 13:21 | #15 Black Bart wrote in post #16091208 Then why the hell don't canon do this. I guess they want to sell more 1D series cameras. I don't think their motives are all that sinister. Canon wants to avoid people complaining about crappy AF performance. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
| Latest registered member is Monkeytoes 1497 guests, 186 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
