Are there any videos for after effects that show how to separate the skin in a grade?
I'd like to grade a scene, but I only want it to effect everything EXCEPT the skin, and then I'd like to grade the skin separately.
AAphotog Senior Member 828 posts Likes: 3 Joined Apr 2012 More info | Jul 05, 2013 13:08 | #1 Permanent banAre there any videos for after effects that show how to separate the skin in a grade? 5d3, 50mm 1.4, 70-200mm F4 L, 17-40mm F4 L
Maverick530 Member 107 posts Joined Jan 2012 Location: Lafayette, LA More info | Jul 09, 2013 01:30 | #2 look at red giant, they have something called cosmo, that might be what your looking for im not to sure though. 6D |60D | 24-105 L | 50mm 1.8 | battery grip | 18-135 |
lecherro Senior Member 809 posts Likes: 6 Joined Aug 2007 Location: Garland, Texas (Outside Dallas) More info | Jul 11, 2013 12:09 | #3 The problem with this is that we are stuck in two dimensions. All the monitors ever see is a grid of pixels... 1920x1080... one way would be to grade the shot twice, Once for the skin and once for the other. then use traveling mattes, rotoscoping, or what ever to cut out and reveal what you want. I know some of the higher end Grading platforms like Davinci, used to use power windows, basically traveling mattes. First step........ Take the lens cap off.
Bwaze Junior Member 28 posts Likes: 3 Joined Sep 2008 More info | Jul 14, 2013 04:27 | #4 http://vision-color.com/color-grading/
| Latest registered member is MWCarlsson 611 guests, 125 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
