Thread started 05 Jul 2013 (Friday) 16:18
1DX and 100-400 Focus Points
picworx
Joined Jun 2005
Jul 05, 2013 16:18 |  #1
On the 1DX the 100-400 lens only displays 21 useable points and then if you install a 1.4x converter it drops to 4 useable points.
The documents I have read indicate I should have 21 useable points with the 1.4x extender but that all 64 points are available?
Trying to flush all this out and help is appreciated.
The Print is What Really Matters
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Jul 05, 2013 16:24 |  #2
Have you tried mounting another 100-400mm onto your 1Dx? I would try that and see if you are still getting the point reduction.
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
Jul 05, 2013 16:24 |  #3
I can use all 61 points on mine w/ the 100-400 installed. I don't have a 1.4x so I can't tell you how many off hand.
Are you sure you didn't limit your 1DX AF to just X-type only?
Julian
picworx
Joined Jun 2005
Jul 05, 2013 16:31 |  #4
I don, t have access to another 100-400 and how would it be limited to X type?
apthai86
Jul 05, 2013 16:33 |  #5
Do you have in settings to only use cross-points? If you do, the available points may be non-cross therefore not showing up.
Canon 5D Mark III (BG-E11 Grip) | Canon 24-70mm f/2.8L II | Canon 70-200mm f/2.8L IS II | Canon 35mm f/1.4L II | Canon 100mm f/2.8 L Macro | FEISOL CT-3442 | FEISOL CB-50DC Ball Head
picworx
Joined Jun 2005
Jul 05, 2013 16:37 |  #6
Where in the menu would this be, I am looking at this now....
cbowlsby
Joined May 2013
Jul 05, 2013 16:42 as a reply to  @ picworx's post |  #7
On my 5d3 it is in the 4th tab of the AF menu under "Selectable AF point".
feedback
picworx
Joined Jun 2005
Jul 05, 2013 16:43 |  #8
Jwcdds
Are you seeing all 61 points solidly lit or are points flashing, there may be a communication issue in thar I only see 21 points solidly lit
jwcdds
Best ofs: 8
Joined Aug 2004
Jul 05, 2013 19:51 |  #9
The other points are "flashing", but doesn't mean you can't use them. (w/o the TC that is)
Julian
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jul 06, 2013 15:10 as a reply to  @ jwcdds's post |  #10
The limitation to cross-type points will give you 21 only, with the EF 100-400 mm f/4L IS USM lens mounted. Otherwise you can select all 61, but the other 40 will be limited to linear only.
When I add the Extender 1.4X III, then I can only select the center point, although it's possible to expand it with the four nearest points.
Anders
picworx
Joined Jun 2005
Jul 06, 2013 15:32 |  #11
I thought I was seeing things and yes 21 points with the 100-400 4.5-5.6 lens and no more than 4 with the 1.4x added
Canon's docs are then accurate.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/07/1/LQ_655304.jpg
Image hosted by forum (655304) © picworx [SHARE LINK]
2,495 views & 0 likes for this thread, 6 members have posted to it.
1510 guests, 132 members online
