I'm thinking Camera Shake Reduction might be a useful tool for those who shoot moving objects handheld. It's only available in PS CC. Here's one review I came across...
http://www.tricedesigns.com …on-in-adobe-photoshop-cc/![]()
Anyone else try it?
Jul 06, 2013 11:46 | #1 I'm thinking Camera Shake Reduction might be a useful tool for those who shoot moving objects handheld. It's only available in PS CC. Here's one review I came across... When you see my camera gear you'll think I'm a pro.
ssim POTN Landscape & Cityscape Photographer 2005 10,884 posts Likes: 6 Joined Apr 2003 Location: southern Alberta, Canada More info | Jul 07, 2013 00:27 | #2 This is one of the exciting options available in CC. However everything that I have read about (I don't have CC yet) it says that it is only for fixing blur/camera shake for shots that were taken from a stationary camera position. I just googled this and looked at 5 different reviews/tutorials of this function and none of them use an example of a moving object. Even the link to the pdf that you supplied shows stationary camera position. In one of the links that I read about this when it was first released the author made a point of telling us that it does not work on panned shots. I'm not sure but I would not make the jump to CC based on this for fixing shots of race cars that are blurry. I'm not sure how they can tell but they say they can and that is detect if the blurriness is due to camera shake or subject movement. I'm sure this will improve as time goes on with future releases. My life is like one big RAW file....way too much post processing needed.
Jul 07, 2013 00:36 | #3 ssim wrote in post #16097854 This is one of the exciting options available in CC. However everything that I have read about (I don't have CC yet) it says that it is only for fixing blur/camera shake for shots that were taken from a stationary camera position. I just googled this and looked at 5 different reviews/tutorials of this function and none of them use an example of a moving object. Even the link to the pdf that you supplied shows stationary camera position. In one of the links that I read about this when it was first released the author made a point of telling us that it does not work on panned shots. I'm not sure but I would not make the jump to CC based on this for fixing shots of race cars that are blurry. I'm not sure how they can tell but they say they can and that is detect if the blurriness is due to camera shake or subject movement. I'm sure this will improve as time goes on with future releases. Thanks for pointing this out. Some how I missed it. I was thinking it would be a good tool for panning...BIF, race cars, aircraft, etc. Bummer. When you see my camera gear you'll think I'm a pro.
mesakid Senior Member 364 posts Likes: 17 Joined Dec 2010 More info | Jul 07, 2013 00:47 | #4 I've used this feature on photos I thought were ruined by being out of focus. However, I was suprised at how well it was able to sharpen the image back up. Now mind you, if you pixel peep you will see that it softens or sort of adds like noise. However, for something being posted to the web at a reasonable size, it has fixed out of focus shots. https://www.youtube.com/that1cameraguy
DThompson Goldmember 4,063 posts Likes: 423 Joined Feb 2008 Location: Georgetown, Ky More info | Jul 07, 2013 08:04 | #5 mesakid wrote in post #16097892 I've used this feature on photos I thought were ruined by being out of focus. Can you show some before/after examples? Dennis
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Jul 07, 2013 08:49 | #6 When they talk about not being able to correct panned shots there are two possiblities, one of which I can understand being uncorrectable. Unless it is a very high shutter speed/slow pan correcting the background is going to be a non starter. Correcting a slight over/under pan, or target starting to move away from the direction of pan should be relativly simple. Not having had a close look at how it works the only possible problem I see is if it only corrects the whole image in one attempt. Even then I would expect that if you have a very plain sky as a background as in aircraft or BiF you should be OK. Otherwise one could always place the target on a separate layer for correction on it's own. I can see no difference between the camera moving in relation to a static target, and the same relative movement to a moving target.
In my case I pan aircraft at slow shutter speeds to capture prop blur. 1/160s, 1/250s are typical shutter speeds I use. A soft image may result from me not tracking the plane properly while panning. But I suspect some of the softness might be due to the up & down jitter I induce while trying to hold a heavy camera/lens. When you see my camera gear you'll think I'm a pro.
| Latest registered member was a spammer, and banned as such! 2246 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
