LucasCK wrote in post #16097480
Hi all..
I know this is a pretty basic thing to do, but for some reason I never quite learnt how to do this properly
I usually set my f stop to about 7-8, crank up the ISO and keep a fast shutter speed and hope that they are still in focus from the time I focus to the time I snap
Would you normally use AI Servo if you wanted to use a wide aperture?
For a shallow depth of field, use a long focal length and a large aperture.
Actual examples from a 70-200mm f/2.8 lens.
Camera Maker: Canon
Camera Model: Canon EOS REBEL T2i
Lens: 70-200mm
Focal Length:
200.0mmAperture:
f/2.8Exposure Time: 0.0008 s (1/1250)
ISO equiv: 100
Exposure Bias: none
Metering Mode: Matrix
Exposure:
aperture priority (semi-auto)White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
Camera Maker: Canon
Camera Model: Canon EOS 60D
Lens: 70-200mm
Focal Length:
178.0mmAperture:
ISO equiv: 100
Exposure Bias: none
Exposure:
Orientation: Normal
Color Space: sRGB
Camera Maker: Canon
Lens: 70-200mm
Focal Length:
178.0mmAperture:
f/2.8Exposure Time: 0.0006 s (1/1600)
ISO equiv: 100
Exposure Bias: none
Exposure:
Orientation: Normal
Using an aperture of f/8 will put most of the subjects in an image in apparent focus. It's the
wrong setting for a
shallow depth of field. ISO and shutter speed don't matter in this circumstance. The important factors are focal length and aperture. Among the basics of photography are that the longer the focal length and the larger the aperture, the shallower the depth of field.
