Thread started 07 Jul 2013 (Sunday) 03:40
1 superzoom or 2 smaller zoom
canondslr
Jul 07, 2013 03:40 |  #1
Hi Guys..
Would you prefer 1 superzoom (ex: 18-200) or 2 smaller zoom (ex: 18-55 + 55-200).
I prefer 18-200 so I dont need to change lens but also thinking that 2 smaller zoom could be nice because if I know I dont need one or the other I can just leave 1 at home, let say I know I'll shoot in smaller place, I can just leave 55-200 at home and have lighter kit.
Please let me know your choice and why.
Thanks.
PH68
Joined Jun 2013
Jul 07, 2013 03:47 |  #2
I've used all 3 lenses you mentioned.
Started with the 18-55 and 55-250, then bought the 18-200 instead.
All are OK, but not great.
I soon realised that a faster lens was more important than a superzoom, particularly in low light indoors.
Most of my pictures were in either the wide range , or at 200m , with little inbetween.
So I now have a fast general zoom, the Tamron 17-50 f/2.8 nonVC and a telephoto prime.
The image quality is far better than the 3 Canon lens I began with.
Fuji XE1 ~ XF18 ~ XF27 ~ XF60 ~ XC50-230
DC ­ Fan
Jul 07, 2013 05:11 |  #3
canondslr wrote in post #16098115 (external link)
Hi Guys..
Thanks.
Perhaps actual pictures from a Canon 18-200mm image stabilizer lens can help answer the question.
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i1174.photobuck​et.com …0806a0003_zpsd2​54bcff.jpg (external link)
http://i1174.photobuck​et.com …131a0000a_zps9e​f7a501.jpg (external link)
http://i1174.photobuck​et.com …806e0000a_zpsd1​fead0d.jpg (external link)
There are no mysterious drawbacks from the Canon 18-200mm IS lens in actual use. You put the lens on a camera, select the focal length and framing, then push the shutter button. Images such as those shown above come out of the camera with no problems or mysteries.
OneJZsupra
Jul 07, 2013 06:21 |  #4
You should skip all of that and get the ef-s 15-85 is lens, have a look at the reviews here.
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
Tom ­ Reichner
Gallery: 168 photos
Location: from Pennsylvania, now in Washington state, road trip back and forth a lot, with extensive detouring
Jul 07, 2013 11:57 |  #5
All of the "superzooms", even the 28-300mm L, seem to give poorer contrast, resolution, and sharpness than the zooms with less range. If you want superb image quality, then you will be better off using multiple zoom lenses. If convenience is of more importance to you, then the zooms with tons of range, like the 11x range of the 18-200 and 28-300, would be a better choice. It is no coincidence that two of Canon's zooms with the best image quality, the new 70-200 and the 200-400, have very short ranges of 2.9x and 2x (w/o the TC), respectively.
DreDaze
Gallery: 48 photos
Jul 07, 2013 12:47 |  #6
i'd rather have two
Andre or Dre
gear list
Instagram (external link)
pulsar123
Gallery: 73 photos
Jul 07, 2013 13:44 |  #7
According to photozone.de review site, 18-55 and 55-250 have much better IQ than Canon 18-200. Here is their verdict for 18-200:
The Canon lens has a couple of weak spots. At 18mm the border resolution is soft and heavy vignetting, extreme barrel distortion and CA problems don't help either. The situation improves significantly at 24mm and 50mm before deteriorating again towards the long end of the range. The situation would have been a bit different a couple of years ago when the sensor requirements were lower but combined with the EOS 50D the lens is somewhat outdated straight from the start. Better look elsewhere unless you still intend to use an older generation DSLR for a while.
In terms of weight, the two kit lenses are actually lighter (by 10g) than 18-200 (200g+390g vs. 600g).
Finally, you get a bit more reach with the kit lenses.
6D, Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, Laowa 15mm 1:1 macro, 50mm f1.8 STM, Samyang 8mm fisheye, home studio
Tommy1957
Joined Apr 2013
Jul 07, 2013 14:52 |  #8
If not having to change lenses is your priority, get the 18-200. I've never used one but it can't possibly be horrible. Be advised that you will take a small IQ hit. If that is acceptable to you, go for it. I realize that I could get some IQ advantage by spending a ton of money on new glass. IQ is generally close to the last thing I consider when buying a lens. I buy for zoom-range, aperture, focus speed or what ever I need that I don't have. If convenience is your top priority, I am sure you will be happy with the 18-200, or maybe even Tamron's 18-270. Nothing wrong with being happy with your equipment.
Tom ­ Reichner
Gallery: 168 photos
Jul 07, 2013 15:58 |  #9
Tommy1957 wrote in post #16099282 (external link)
Wow. I had to read that twice to be sure it said what I thought it said. If IQ in a lens is not important to you, then how are you able to take images with awesome image quality? Don't the optics of the lens have an enormous effect on the quality of the final image? The best sensor in the world won't give you perfect pictures if you match it with a sub-par lens. If you ignore lens IQ when making a lens purchase, then the quality of your images will suffer - there's just no way around that.
DocFrankenstein
Joined Apr 2004
Jul 07, 2013 16:08 |  #10
Tom Reichner wrote in post #16099462 (external link)
I agree with him. You get the lens for the features it offers, not for the image quality. If you need a hyperzoom, it means you can't or don't want to change lenses and that's the only lens that'll suit you.
National Sarcasm Society. Like we need your support.
archer1960
Gallery: 6 photos
Jul 07, 2013 16:12 |  #11
Hi Guys..
Thanks.
Tamron 18-270. For me, the convenience of not having to swap lenses beats the slightly better IQ of covering that range with multiple lenses about 90% of the time. There are exceptions when I'll slap on a prime, but those are relatively rare for my shooting.
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
Tommy1957
Joined Apr 2013
Jul 07, 2013 16:38 |  #12
What? This makes no sense. Say you put IQ first. Say the Canon EF 24-70 f/2.8 USM II is THE highest IQ lens you can get. So what? How is it going to help you take a photo at 400mm f/2.8, or 24mm f/1.4? You can't possibly make the shot you want, but damn, you've got a really nice lens.
A second point, if you please. There is a LOT more to an image than IQ. A lot more. Exposure, composition, content, framing, PP, emotion, love and the list goes on. I have a picture of my grandson, aged 3 years, that he took of himself. Photographically speaking it is horrible. I love it. His mother loves it. If you are as consumed by IQ as your post seems to suggest, you are missing the entire point of photography.
I would suppose that there are a handful, at best, of photographers in the world who NEED THE BEST IQ lens, and can make it perform at that level all the time. I am not among them. I shoot the best equipment I can afford. If I had the money, I'd be shooting a 1Dx and a 24-70 II. I don't. I am content with my 60D and Tamron 28-75. I come from a film background. Forty years ago nobody worried about IQ. You bought a lens for just the reasons I listed: focal length/zoom range, aperture and characteristics of the lens. The current obsession with IQ is a by-product of the digital age. I for one, make better photographs when I worry about the image, not the image quality. I prefer it that way.
EDIT: Tom, I had a look at your gallery. Exquisite images. Perhaps we just have a different perspective on photography. I can see that you take top-quality images and I assume you use top-quality equipment. Congratulations on your equipment and your talent. I have lesser degrees of both. Most of the shots I take are family-snap-shot-remember-the-moment types of images. We seem to have different philosophies on the art of photography. Photography is a broad term, there is room for all of us, and our equipment and talent under that umbrella.
Tom ­ Reichner
Gallery: 168 photos
Jul 07, 2013 17:30 |  #13
Tommy1957 wrote in post #16099583 (external link)
Tommy,
Thank you for your response. I value seeing photography from someone else's perspective. I must admit, I would probably find photography more fun and less stressful if I did not put so much emphasis on IQ. But then the results may not be entirely pleasing to me. There's always a tradeoff, isn't there?!
Tommy1957
Joined Apr 2013
Jul 07, 2013 18:06 |  #14
Tom Reichner wrote in post #16099708 (external link)
Tommy,
As I said, I looked at your images. Please, do continue whatever it is you are doing. Lots of us aspire to your skill level. I know I do.
reprazent
Jul 07, 2013 18:21 |  #15
Superzooms have their place, (one lens travel solution for example) but if IQ is your main concern then you're better off with the kitzooms. IMO these lenses are underrated. Sure they are plasticky, but they are also lightweight and small.
gearlist | flickr (external link)
1,934 views & 0 likes for this thread
Latest registered member is RBSP
911 guests, 227 members online
