Thread started 09 Jul 2013 (Tuesday) 22:17
First time lightstand/B800 user... what is wrong here?
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Jul 09, 2013 22:17 |  #1
Got my light stands in. Ravelli ABSL background stands that I'm using for my light stands for now and trying to attach the B800 to it and although it tightens up the pin design allows it to wiggle. I'm certain this can't be the right pin setup to use.
what am I suppose to be using here. help! lol... thanks
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/07/2/LQ_655667.jpg
Image hosted by forum (655667) © Talley [SHARE LINK]
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
flowrider
Gallery: 127 photos
Jul 10, 2013 00:08 |  #2
Did you loosen the AB screw out fully so it drops completely onto the light stand shaft?
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
erdons
Joined Oct 2011
Jul 10, 2013 02:57 |  #3
Loosen the screw till it slides all the way on there then screw it tight and it should be wiggle free.
5D Mark III|7D Mark II|60D|T3|24-70/f2.8|70-200/f2.8L MK II ||Canon Speedlite 600 EX RT|Canon Speedlite 580EXII|2x Alien Bee B800
CAPhotog
Joined May 2012
Jul 10, 2013 09:12 |  #4
Have you tried flipping the threaded stud around? One end is actually longer than the other and looks like you are trying to attach to the longer end in your photo. If that doesn't work, I'd suggest purchasing a female stud (pin) without the threads.
SMP_Homer
Gallery: 29 photos
Jul 10, 2013 13:52 |  #5
I have a dozen stands/brackets/monopo​ds/etc to screw these onto
for the most part, its tight, but there are a couple that have a little bit of wiggle... still feels safe and has no impact on what I'm trying to do...
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Jul 10, 2013 13:56 |  #6
SMP_Homer wrote in post #16108295 (external link)
This
A little wiggle is not really an issue unless you are working in hurricane force winds. The weight of the light and modifier holds them in place unless there is some force providing lift.
Going ­ Baroque
Jul 10, 2013 14:11 as a reply to  @ gonzogolf's post |  #7
Yeah, the little wiggle is really not an issue once the set screw is tight, but some of those receptacles on the newer alien bees really are cruddy. I don't know if it's a bad batch or what, but a few of mine don't fit well at all with any of the stands I've used.
gonzogolf
Gallery: 561 photos
Jul 10, 2013 14:15 |  #8
Going Baroque wrote in post #16108356 (external link)
How are they different? How are they failing? Its a set screw in a round tube, it cant be that much different.
Going ­ Baroque
Jul 10, 2013 14:24 |  #9
gonzogolf wrote in post #16108364 (external link)
LOL Now you know how frustrated I was when the new lights showed up and they just don't fit as well as before.
I haven't taken the time to figure it out for sure, but I suspect that the tube tapers a little bit towards the top/inside. Basically, the round tube isn't really round.
Wilt
Jul 10, 2013 16:40 |  #10
Measuring on my monitor, the brass spigot is 15mm long to the upper wide area, while the threads add about 4mm to the length. Meanwhile the AB mount hole appears to be 15mm deep, so unless there is sufficient smaller hole for the threads, the spigot is sitting about 4mm out of the AB mount and prevented from seating fully by the length of the threads.
SkipD
Joined Dec 2002
Jul 10, 2013 16:57 |  #11
If you have no use whatsoever for the threads on the end of the 5/8" spigot, then simply use a hacksaw to remove the threaded portion. That will make it easier to mount a light to the spigot.
Skip Douglas
Going ­ Baroque
Jul 10, 2013 17:31 |  #12
Not to put too fine a point on it, but I checked it with the back end of a drill bit, and the bit gets caught by a little ridge inside the hole (preventing the light front seating properly in every stand I've used). Just a little bit of deformation inside there, and I will just bore it out so that inside diameter is more uniform.
I took some pics of the old and new parts on the strobe. Old is on top, and it used a thicker metal liner. New is on the bottom, and the liner appears to be plastic. The "ridge" is just inside of where the liner ends.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/07/2/LQ_655749.jpg
Image hosted by forum (655749) © Going Baroque [SHARE LINK]
CptTripps
Joined Mar 2011
Jul 11, 2013 02:50 |  #13
All plastic? That saddens me.
60D - Sigma 30mm 1.4 - 50mm 1.8 ImkII - 18-135 IS - 70-200 2.8 mkII - 2x430ex II - 3xFlextt5+AC3 - Einstein 640 w/mc2 - Vagabond Mini
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Jul 12, 2013 11:33 |  #14
Wilt wrote in post #16108782 (external link)
So this is called a spigot?
This has threads because it's for a background stand. The cross bar fits over this then you use a washer and wingnut to lock it down. I do not want to cut the threads.
I need to order a spigot that will work out better. It wobbles pretty good. I don't want any stress
My Gear Archive
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Jul 12, 2013 11:39 |  #15
screw it i can get a piece of pipe and use it. be stronger than anything out there.
topic done.
My Gear Archive
2,233 views & 0 likes for this thread, 10 members have posted to it.
2293 guests, 132 members online
