Can anyone tell me two things about this flash please?
1. Will it only sync with the 5D mk2 at 1/100s ( I read this is true but surely it can't be? )
2 Why is the non RT version more expensive than the RT?
Thanks for your help
willie45 Member 111 posts Likes: 17 Joined Jul 2007 More info | Jul 10, 2013 18:32 | #1 Can anyone tell me two things about this flash please?
MFG Senior Member 537 posts Likes: 7 Joined Sep 2008 Location: South Australia More info | Jul 10, 2013 18:52 | #2 1. turn on the HSS and you can sync beyond 1/100s. AIPP Accredited (Australia), WPJA
Jul 10, 2013 19:26 | #3 I never had any problem using my 5D2 with any of my 600EX-RT flashes; no issues with HSS or with max-sync speed (and it was this latter issue--max sync speed--that the OP was referring to, I believe). Yes, the manual will tell you that all pre-2012 cameras can't utilize max-sync speed or HSS but that hasn't been my experience. One thing you can't do is use Group Mode (so you can have your on-camera 600 in E-TTL, for example, and your off-camera 600 in Manual, or vice-versa). Now that I shoot with the 5D3, I must say I love the Group Mode. the site
Jul 10, 2013 19:27 | #4 Thanks for your reply. But is the sync speed on the older camera really 1/100s if I don't choose HSS?
Jul 10, 2013 20:58 | #5 MFG wrote in post #16109122 1. turn on the HSS and you can sync beyond 1/100s. 2. get the RT -> end of story. Canon made non-RT for some countries that they cant use the radio freq (if i remember correctly). no point getting the 600ex (non-rt), get the 580ex2 instead. What? Rand
apersson850 Obviously it's a good thing More info | I think you are mixing things up. Canon's caution about sync speed are related to when you use this combination:
Then user's tests have shown that the caution is a bit on the safe side, as noted above. Anders
dmward Cream of the Crop More info | Jul 12, 2013 18:23 | #7 In the US we call that CYA and corporate lawyers encourage marketing managers to do it all the time. David | Sharing my Insights, Knowledge & Experience
pstyle1 Senior Member 317 posts Joined Jun 2012 Location: DC/VA More info | Jul 13, 2013 04:00 | #8 I got around this by buying 5D MKIII's to accompany my 600's 5D MkIII x2 + a lot of L's.
dmward Cream of the Crop More info | Jul 13, 2013 09:32 | #9 ^^^ There is that solution. Worked for me as well. David | Sharing my Insights, Knowledge & Experience
apersson850 Obviously it's a good thing More info | Cheaper than solving it with the 1DX. Anders
dmward Cream of the Crop More info | Jul 14, 2013 15:38 | #11 And now the 6D or 70D are options. David | Sharing my Insights, Knowledge & Experience
| Latest registered member is semonsters 1457 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
