Thread started 11 Jul 2013 (Thursday) 14:10
batch file name change?
longspur
Joined Apr 2013
Jul 11, 2013 14:10 |  #1
My wife and I both shoot 5D m2's at weddings. When we download images, we want them combined in the same folder. Occasionally, the two cameras assign the same file names. We use iMac and Macbook Pro, LR, and PS, if that matters.
When this occurs, is there an easy way to do filename change on a large number of raw images?
Is there an easy way to prevent this from happening to begin with?
Thanks in advance,
Hi; I'm Robbie and, I have a thinking problem.
(2) 5D mk2, 40D, Canon 85, 100 macro, 50L, 24-70L, 16-35L, (2) 70-200L, (2) 580 EXII's, (2) Alienbees
www.copperhoundphotogr​aphy.com (external link)
Nightstalker
Jul 11, 2013 15:55 |  #2
The 5D MK3 allows you to create custom filemanes whereas the MK2 dows not so there is no 100% guaranteed way of stopping it from happening.
There are bulk renaming apps out there and for MAC GOOGLE found these 3 :
http://mac.tutsplus.co​m …-rename-files-on-the-mac/ (external link)
Heath
Joined Sep 2009
Jul 11, 2013 16:15 |  #3
What DAM software are you using?
Do you use Lightroom? You can either do it on import or in the Library.
Or there are other options.
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blog (external link)-Twitter (external link)-Zenfolio (external link)-500px (external link)-Pinterest (external link)-Gear List
kirkt
Jul 11, 2013 19:21 |  #4
I use this:
http://www.mrrsoftware​.com/MRRSoftware/NameC​hanger.html (external link)
on the Mac. Works great. Free.
Kirk
Kirk
tonylong
...winded
Gallery: 60 photos
Jul 11, 2013 19:26 |  #5
Lightroom makes it easy/simple using the Import dialog -- you can rename using one of numerous naming options. When I download/import from two different cameras I just assign a common shoot "name" and add the camera-specific info (or the shooter's name) and then LR adds a sequence number to each set, so each file has a unique name.
Tony
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jul 11, 2013 23:08 as a reply to  @ tonylong's post |  #6
1. Not sure about the 5D2 but the 5D3 allows you to add a user defined prefix to file names. Having a unique prefix for each camera would solve the issue.
2. Tony's suggestion above. I have an import prefix that changes the name of files on import.
Dan Marchant
longspur
Joined Apr 2013
Jul 12, 2013 01:21 |  #7
Thank you so much for the responses. I'll give it a whirl in the morning with LR. If that doesn't work, I'll try one of the apps. Many thanks, again.
René ­ Damkot
Jul 12, 2013 11:38 |  #8
You might also want to give ImageIngester (or Ingestamatic) a try.
http://basepath.com/si​te/ (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
730 views & 0 likes for this thread, 7 members have posted to it.
1698 guests, 139 members online
