Hello everybody,
Here's a picture I took of my son. I adjusted lighting levels in PSE. Please let me know what you think! I can handle it...good or bad.
Thanks!
JennB GoldLurker More info | Jan 23, 2006 10:22 | #1 Hello everybody, ~ Jenn ~
dzs1945 Member 93 posts Joined Dec 2005 Location: "Lank custer", PA More info | Jan 23, 2006 10:39 | #2 don't know much about pics but you have a very hansome son!!!
Thank you for the nice comment, Daniel! ~ Jenn ~
rohitkumar Member 67 posts Joined Jan 2005 Location: Connecticut, USA More info | Jan 23, 2006 12:18 | #4 |
Thank you, rohitkumar! Is there anything I could have done better? Is the picture too bright? ~ Jenn ~
ajbalazic Cream of the Crop 5,228 posts Joined Jan 2005 Location: Kitchener, ON, Canada More info | Jan 23, 2006 12:51 | #6 It's a great portrait. I like the tight crop and composition. You've really got a tight dof here- good job getting the eyes in focus (although I don't think it's perfectly focused). As for lighting- maybe a little light, did you try adjusting the levels? Regardless, I think the extra exposure works well here. Who says that the exposure always has to be exactly as we see it in "real life" anyway. Alan
Hi Alan, ~ Jenn ~
Robert_Lay Cream of the Crop 7,546 posts Joined Jul 2005 Location: Spotsylvania Co., VA More info | Jan 23, 2006 15:06 | #8 Very unusual lighting. The primary light seems to be coming from below the subject - note that the lower half of his face is brighter than his forehead. Bob
Hi Bob, Composition is good for a candid shot, with one exception. Try to avoid having an important element of the primary subject from coming into contact or very near contact with the frame, as does his chin. Since you are using a Rebel XT, the aspect ratio we see here (3:2) is normal for that camera, which suggests that you did not crop the image. Therefore, at this stage there is no way to avoid the chin at the frame. Thanks for the advice! I do need to watch out for shooting too close-up that I cut off the top or bottom part of the face. My son was getting a bit antsy when I was taking this picture. I was actually quite lucky to get this shot as he is usually giving me a goofy face. ~ Jenn ~
Hellashot Goldmember 4,617 posts Likes: 2 Joined Sep 2004 Location: USA More info | Jan 23, 2006 20:56 | #11 Permanent banThe original image looks better. That edit has weak colors in comparison. Portrait orinetation might have been a better for a face shot. 5D, Drebel, EOS-3, K1000
Jan 24, 2006 04:00 | #12 It's a wonderful capture and I think the light background has worked well as it brought a softness to the image. I had a play to enhance that feeling and also tweaked the white balance. -- PXL8
Very nice image. I would try going back into PS and use levels and curves to remove the orange/red color cast. I did a edit in PS to give you an example. Once again very nice image. Hi Jim, The original image looks better. That edit has weak colors in comparison. Portrait orinetation might have been a better for a face shot. Hi Hellashot, It's a wonderful capture and I think the light background has worked well as it brought a softness to the image. I had a play to enhance that feeling and also tweaked the white balance. Hello Pxl8, ~ Jenn ~
MALI Senior Member 430 posts Joined Aug 2005 Location: Bloomington, IN More info | Jan 24, 2006 08:23 | #14 For me, color cast does not work for this shot and I know what you mean when you say you like color casts. Canon 20D, 10-22, 24-70L,70-200L f/2.8 IS, 580 EX, RS-80N3, EP-EX15, BG-E2, E1.
usukshooter Senior Member 337 posts Joined Dec 2005 Location: Manchester, UK More info | Jan 24, 2006 08:37 | #15 I wouldn't go as far as Mali but I do have to agree the color cast ruins the image. It's unnatural and unflattering.
| Latest registered member is semonsters 886 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
