Hey all,
Long time i didn't post here.
I would like to buy a tilt shift lens finally, but not sure which one of the two i should get, 17mm or 24mm?
Applications: Interior design, architecture, landscapes, and some still life shots too.
Tareq "I am very lazy, a normal consumer" More info | Jul 22, 2013 13:12 | #1 Hey all, Galleries:
Burnzz Member 119 posts Likes: 1 Joined Mar 2009 Location: Mountain West, USA More info | Jul 22, 2013 15:40 | #2 |
CanonBob Goldmember 2,063 posts Likes: 52 Joined May 2007 Location: Poitou-Charentes, France More info | Noting that you have "landscape" in your list, the 24mm version is a lot more filter friendly than the 17mm. It's certainly possible with the 17mm but requires a bit of home construction to get something workable. 1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
Jul 22, 2013 16:53 | #4 Ok, i know about the filter issue with 17mm, but i was thinking if most of the time i will not use filters, the only time i will use filters is when i will shoot landscapes at day time and with clouds, but indoors and nightshots and even cityscapes at night i tend not using filters, so it is like 85% i will not be using the filters, but i can see that 24mm getting more votes anyway. Galleries:
| Latest registered member is semonsters 1463 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
