Thread started 24 Jul 2013 (Wednesday) 18:55
How to make your pictures "pop"
milleniumking
Joined Jan 2013
Jul 24, 2013 18:55 |  #1
Hi guys and gals, I have been looking at some of the pics you guys post, and I must say I am amazed! Besides the sharpness of the pictures, the color is outstanding. Which brings me to the question, how do you make the images stand out and POP!
Currently I am using the "faithful" setting on my body and have L glass... 24-105 and 70-200.
Any suggestions????
Thanx
snerd
Joined Nov 2010
Jul 24, 2013 19:06 |  #2
Only a noob here, but I was using "Faithful" and went to "Neutral" and noticed a difference. I also might do a small amount of PP in Lightroom as I learn it. It's amazing what you can do with bad shots using raw and LR!!
Mag-1981
Gallery: 16 photos
Joined May 2012
Jul 24, 2013 19:16 |  #3
Technique, composition and a good glass is one thing, but you'll also need a good software to post process your photos. Almost 100% of photographs you see on the net or elsewhere, were processed using the software. In most cases, you would be suprised, if not shocked to see before and after.
BTW, you have some great glass, capable of producing these images of the quality you're talking about.
DC ­ Fan
Jul 24, 2013 19:29 |  #4
milleniumking wrote in post #16151058 (external link)
Any suggestions????
Thanx
Start with increased saturation. Also consider increasing sharpness and contrast.
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Jul 24, 2013 19:29 |  #5
Shoot in Raw, learn to post process your images. It makes all the difference. Join NAPP, or Lynda, or even Kelby Training. There's a lot to learn both about seeing the light, creating the light, and processing the files to make the images stand out.
500px (external link)
1x (external link)
instagram (external link)
tagnal
Jul 24, 2013 19:31 |  #6
check out some threads such as this one:
https://photography-on-the.net/forum/showthre​ad.php?t=684360
5D3 / M3 / S100 / Σ 35 Art / 50 1.8 / 135 L / 17-40 L / 24-70 L / 70-200 f/4 IS L / m 22 2.0 / 580ex II
Toy List | flickr (external link) | FAA (external link)
icacphotography
Joined Jan 2013
Jul 24, 2013 19:33 |  #7
DC Fan wrote in post #16151140 (external link)
QFT. This is usually what I do to my images for the most part. I also edit out flaws via either cropping or using clone/healing brushes. Learning how to use adjustment brushes to finally adjust parts of a photo is a big tool to making your photos pop (for example adjusting the exposure and such of just the iris of the eyes in a portrait can do wonders to make the eyes pop)
Body:50D gripped Magic Lantern'd
Lenses:50mm 1.8,40mm 2.8,28-105 USM II,70-210 F4, 1962 Asahi Pentax Super Takumar 55mm 1.8
Flash: Canon 430 EX
The camera is just a tool - it is not responsible for the picture.
MikeFairbanks
Jul 24, 2013 19:39 |  #8
There are several tricks. Maybe tricks is the wrong word. Techniques. I don't have much room to talk, however, as I'm still learning this myself. I get lucky sometimes with "pop".
My suggestions are the following:
1. Shoot Raw AND Jpeg. The camera's engineers should not be discounted. If you take a good shot and it comes out great in Jpeg, then be happy. Sometimes the Jpegs out of camera are really good. Shooting in Raw gives you more room to work with it, of course, but Raw comes out relatively bland. It's up to you to work on it and make it pop. Raw is awesome, but it's not perfect. You have to know how to process.
2. Lightroom will not see things the same way Canon's software sees things, so you might get a file that looks a little different in lightroom.
But mostly listen to people, especially those whose work you admire.
Thank you. bw!
kcrunchone
Gallery: 35 photos
Joined Feb 2013
Jul 24, 2013 19:46 |  #9
I have heard that a ton of behind the pc time is spent to get the pics to pop. I am a noob and have been just trying to treat the camera like a 35mm. I want the pic to pop from the memory card and if I can get it better in a program then ok. What programs are you guys & gals using to get the fantastic results I am seeing around the site?
1D X MII
7D MII Gripped 6D Gripped 60D Gripped Canon 100-400 L IS Canon 50 1.8/Canon 100 2.8/Canon 28-135IS/Canon 70-200 F4L/Tamron 18-270 3.4/ Sigma 2.0 Ext. Kenko 1.4 Canon 16-35 F2.8 L Sigma 150-600 C Canon 500L 4.5
http://www.flickr.com/​photos/kcrunchone/ (external link)
icacphotography
Joined Jan 2013
Jul 24, 2013 19:51 |  #10
I personally use Lightroom with a bunch of addons from Nik software to PP my images. If you want to treat the camera like a 35mm and really make your images pop I have some settings I use for when I do shoot JPEG (rarely) I use the standard picture style and bump sharpening 1 notch and everything else 2 notches and it produces images with tons of pop,contrast and saturation.
Flash: Canon 430 EX
stsva
Gallery: 45 photos
Jul 24, 2013 19:52 |  #11
If using Lightroom, clarity, vibrance, and the whites and blacks sliders will have the greatest effect, combined with a curves adjustment as needed.
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Jul 24, 2013 20:00 |  #12
kcrunchone wrote in post #16151187 (external link)
Lr and Ps. Honestly, sometimes the light and subject are right and the images look great. Sometimes the light forces a compromise that you have to anticipate and correct in post. Either way, you'll always need some post work, even if it's just some sharpening. Lighting is key, good light makes a good image. You still need to be able to visualize the potential and shoot with an eye to optimizing what's available; both with the original capture and with processing.
1x (external link)
milleniumking
Joined Jan 2013
Jul 24, 2013 20:19 |  #13
Thanx for the responses. I dont use LR or any PP software and when I do I am just messing around with it. I am definately going to try and bump up the saturation and sharpening in camera and give it a shot. Hopefully I can post some pictures soon showing my improvement!
Thanx
MakisM1
Gallery: 50 photos
Joined Dec 2011
Jul 24, 2013 20:25 |  #14
Why don't you post an example of a photo that you like and you would like more 'pop' and see what folks can do with it?
You will need to change your profile to allow for editing, so folks can work on your photo...
Gerry
Mag-1981
Gallery: 16 photos
Joined May 2012
Jul 24, 2013 20:27 |  #15
milleniumking: just try and download the trial version of the LR5 from Adobe website. You'll have 30 days to play with it. There is plenty of tutorials available, including those included with the LR itself. It really is not that difficult. Just play with it and I am sure you'll acquire a lot of knowledge and you'll be able to suprise yourself with the results.
21,356 views & 0 likes for this thread, 44 members have posted to it and it is followed by 4 members.
1445 guests, 132 members online
