Thread started 26 Jul 2013 (Friday) 17:17
Got a good tip for this frustration?
RandMan
Joined Mar 2012
Jul 26, 2013 17:17 |  #1
I have a circular polarizer that does not seem to want to unscrew from a step-up ring that it's currently attached to. I've tried a few times today, and my last attempt was to try some rubbery/tacky cabinet and cupboard liner to get a better grip on things, but to no avail.
I know this probably happens to people a lot - got any nifty little tips or suggestions for me?
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
pdrober2
Joined Nov 2010
Jul 26, 2013 17:42 |  #2
a rubber band works well. wrap it around the part closet the the threads and give it a turn
Fujifilm X-T1 | 23 | 27 | 56 | 90 | 55-200
Feedback
Jon
Joined Jun 2004
Jul 26, 2013 17:54 |  #3
Press the step-up ring against a tire or a rubber jar opener and use the aforementioned rubber band on the filter, if you can't get a set of appropriately-sized filter wrenches (something any filter user should have in their bag).
Jon
Cocker Spaniels
Nathan
Can you repeat the question, please?
Gallery: 18 photos
Jul 26, 2013 17:55 |  #4
i don't screw mine on too tight and a lot of times i notice just fiddling with it lightly is better than trying to really grip it
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 50L | 85L II | 100L | 135L | 580 EX II x2
RandMan
Joined Mar 2012
Jul 26, 2013 18:24 |  #5
Jon wrote in post #16156585 (external link)
Filter wrenches. Yes, filter wrenches. I definitely should invest in those - thanks. I'll try the tire/rubber band method in the meantime.
Nathan wrote in post #16156588 (external link)
That's what I've always found. Most of the time the tighter I grip them when removing, the harder it is for them to budge; I'm assuming because the metal is so thin and flexible it's getting shoved into the threads by the force of your grip. This time, however, it stuck and it really wants to remain stuck.
mondayshift
Joined Apr 2011
Jul 26, 2013 18:32 |  #6
blow dry the filter ring on low heat, just enough to warm it a bit and then use the rubber band or whatever you wanna use to get a better grip. use at your own risk of course.
“Sucking at something is the first step towards being sorta good at something.”
- Jake the Dog -
roqdawg
Jul 26, 2013 18:37 as a reply to  @ mondayshift's post |  #7
You can try holding the (filter side) in front of a cool stream of a/c few a few seconds to let it contract and thus loosen up.
Roqdawg
Canon R5 | R7 | RF 15-35mm f/2.8L IS | RF 24-70mm f/2.8L IS | RF 100mm f/2.8L IS macro | RF 100-500mm f/4.5-7.1L IS | RF 600mm f/4L IS | RF 800mm f/11 IS | RF 1.4X & 2X Extenders |430EX III-RT | 600EX II-RT | EL-5 |Canon Pro-10 Printer |
Nathan
Gallery: 18 photos
Jul 26, 2013 19:51 |  #8
lol... two conflicting bits of advice back to back ^^^
I've also put on a pair of leather gloves to help me grip. Rubber gloves would work, too... but I just grabbed what was handy.
canonphotog
Joined Nov 2005
Jul 26, 2013 20:07 |  #9
Don't overthink this. More often than not when a polarizer is "stuck" all you have to turn is turn the adjustable part of the polarizer counterclockwise a few times and the threaded portion will release. Can't explain why it works, but it's always worked for me.
-Ken
Gear List|Kenny D. Photography (external link)
NU27D
Jul 26, 2013 20:24 as a reply to  @ canonphotog's post |  #10
Heat /cold for expansion and contraction and a pair of latex gloves. I carry latex gloves and a few rubber bands in my bag.
Rstanford
Jul 26, 2013 23:29 |  #11
mondayshift wrote in post #16156682 (external link)
This
RandMan
Joined Mar 2012
Jul 27, 2013 11:43 |  #12
Eureka! I finally got it off just now. Rested it directly on the vent of my air conditioner for a few minutes until the whole thing was icy cold, then just squeezed the step-up ring ring my bare hand and turned the filter with my other hand and a rubber cabinet liner - came off quite quickly and easily.
Thank you all for a little contraction/expansion tutelage!
Wilt
Jul 27, 2013 12:17 |  #13
aluminum polarizer ring screwed into another aluminum filter or step up/down ring is asking for trouble to happen...the real need for a brass ring polarizer, now that lenses are mostly composites and not metal.
Phoenixkh
a mere speck
Gallery: 67 photos
Joined May 2011
Jul 27, 2013 13:14 |  #14
I'm glad my advice wasn't needed, i.e. a Sawzall. ;)
Kim (the male variety) Canon 1DX2 | 1D IV | 16-35 f/4 IS | 24-105 f/4 IS | 100L IS macro | 70-200mm f/2.8L IS II | 100-400Lii | 50 f/1.8 STM | Canon 1.4X III
RRS tripod and monopod | 580EXII | Cinch 1 & Loop 3 Special Edition | Editing Encouraged
mak65
Jul 27, 2013 15:46 |  #15
Phoenixkh wrote in post #16158486 (external link)
Mine too. I was going to recommend banging it against a kitchen counter top, much like removing a lid from a jar. :D
3,405 views & 0 likes for this thread, 17 members have posted to it.
1061 guests, 102 members online
