Thread started 27 Jul 2013 (Saturday) 23:45
Better bokeh lens
mgnike1
Jul 27, 2013 23:45 |  #1
Hello, considering buying 85L for portraits....I get decent bokeh with my 70-200 2.8 but not sure if there's a big difference in bokeh between the two lenses. Any suggestions would be appreciated. Thanks in advance!
Rashkh
Joined May 2011
Jul 28, 2013 00:29 |  #2
The lens sample photo archive should have a ton of portraiture from both lenses. You should look there to see if it's worth the purchase. I would recommend looking at the 135L as well, assuming it's not too long.
tkbslc
Jul 28, 2013 00:53 |  #3
In terms of amount of blur, 200mm at f2.8 and 85mm at f1.2 are similar, but due to the perspective difference for similar framed portraits, the look is very different.
Taylor
60D | ELPH 330 | iPhone 5s
Mornnb
Gallery: 6 photos
Joined Aug 2012
Jul 28, 2013 01:48 |  #4
tkbslc wrote in post #16159825 (external link)
Yes. And the 200mm is going to be sharper at 2.8 than the 85mm is at 1.2.
The best compromise is probably the 135mm f2..
Canon 5D Mark III - Leica M240
EF 16-35mm F/4 IS L - EF 14mm f/2.8 L II - - EF 17mm TS-E L - EF 24-70mm f/2.8 L II - EF 70-200mm IS II f/2.8 L - Sigma 35mm f/1.4 Art - Sigma 85mm f/1.4 EX
Voigtlander 15mm III - 28mm Elmarit-M ASPH - 35mm f/1.4 Summilux-M FLE - 50mm f/1.4 Summilux-M ASPH
500px (external link)
ICarumba
Joined Jun 2013
Jul 28, 2013 03:48 as a reply to  @ Mornnb's post |  #5
With the same framing the 85 at 1.2 is equal to 70-200 at 200 and 2.8? In terms of blur Amount?
smorter
Jul 28, 2013 05:03 |  #6
They can't be compared unfortunately as the perspective is way different
With a far away background the 200mm will look blurrier
Wedding Photography Melbourneexternal link
Reviews: 85LII
FuturamaJSP
Jul 28, 2013 05:47 |  #7
Mornnb wrote in post #16159910 (external link)
sharpness isn't everything
besides in this case you would probably have to do a 100% crop to see the difference.
Personally I think the best compromise would be sigma 85 f1.4 if the op cant afford the 85L
They asked me how well I understood theoretical physics. I said I had a theoretical degree in physics. They said welcome aboard! - Fallout New Vegas
blah blah blah
DA (external link)
Xcelx
Joined Sep 2009
Jul 28, 2013 06:30 |  #8
ICarumba wrote in post #16159986 (external link)
Wide open the 85 will have more background blur. I can't comment on the bokeh or quality of the blur between the two though, since I only own one of them.
http://howmuchblur.com ….8-on-a-0.9m-wide-subject (external link)
gasrocks
Jul 28, 2013 08:55 |  #9
Bokeh is not a term meaning smooth background nor little DOF.
cdang
Joined Dec 2011
Jul 28, 2013 08:58 |  #10
I like the 85L bokeh more.
Wilt
Jul 28, 2013 14:22 |  #11
Some examples from POTN
85mm f/1.2 lens
https://photography-on-the.net …p?p=12565528&po​stcount=79
https://photography-on-the.net …?p=12610602&pos​tcount=137
https://photography-on-the.net …?p=12632812&pos​tcount=153
Unfortunately most folks don't mention FL setting when they post shots taken with zooms, in the examples archives, so it is hard to get direct comparisons. Ideally, one would compare the two lenses at same FL, to mimic portraiture usage within the fixed confines of a interior shooting space...
70-200 f/2.8 USM (not IS, OP didn't state which one is owned)
https://photography-on-the.net …p?p=6770158&pos​tcount=250
https://photography-on-the.net …?p=10339459&pos​tcount=467
https://photography-on-the.net …?p=12287477&pos​tcount=766
https://photography-on-the.net …p?p=7481478&pos​tcount=276
Revolverz
Joined Sep 2012
Jul 28, 2013 14:27 |  #12
200mm @ f2.8 WON`T produce more background blur then the 85L.
200mm@ f2.8 will produce the same ammount of blur ONLY if the background is far, at more than 300m away from the subject. In ANY other case.. with background closer, 85L will produce much more blur. (see link)
Website: www.cristian-popa.com (external link) ___Facebook: https://www.facebook.c​om/cristian.popa.art (external link)
DanAnCan
Joined Jul 2012
Jul 28, 2013 14:30 |  #13
+1 on the 135 if its not too long
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i1196.photobuck​et.com …/224A2610_zps6b​833ebc.jpg (external link)
Canon 5D3/5D2/8-15L/24-70LII/Σ35/85LII/135L/200L F2/Σ300 EX DG/EF TC 1.4 & 2X III/EX580 II/ PCB Busy Bee Kit
Wilt
Jul 28, 2013 14:35 |  #14
AMOUNT of background blur is only one consideration, 'bokeh' is the QUALITY of blur. Not sure what OP meant in the inquiry 'better bokeh', as the term 'bokeh' is all too often used in the wrong context by folks! Is 'better' meant by OP as 'more blur' (the incorrect common usage), or is 'better' meant to be 'more pleasing' (the proper usage)?
Feryll
Joined Apr 2012
Jul 28, 2013 14:51 |  #15
I do believe that both 85 1.2 and 135 f2 are better portrait lens than the 70-200.
5D | 17-40L | Σ 50 1.4
Former: 30D | 1D Mk II |18-55 IS | 55-250 IS | Tamron 17-50 | 28 1.8 USM | a few manual lenses
6,589 views & 0 likes for this thread
Better bokeh lens
934 guests, 230 members online
