I want to buy something cheap before I can finally afford the 135 f2L.
I do think that 85 1.8 and 100 f2 are almost identical in optical design, IQ and build quality.
Which do you think is the preferable focal length?
Feryll Member 101 posts Likes: 1 Joined Apr 2012 More info | Jul 29, 2013 11:58 | #1 I want to buy something cheap before I can finally afford the 135 f2L. 5D | 17-40L | Σ 50 1.4
Nightdiver13 Unabashed nerd! 2,272 posts Likes: 38 Joined May 2010 Location: Bigfoot Country More info | Jul 29, 2013 12:38 | #2 Both would be fine. There is no generally preferable length, only what is preferable to you. If your plan is to get the 135, I'd get the 85 since you'd be more likely to keep it once you've purchased the 135. — Neil
victordeng Member 126 posts Joined Dec 2012 Location: United States More info | Jul 29, 2013 12:46 | #3 85, One day, you'll probably get FF and 85 and 135 is a nice combo. Canon Equipment, Elinchrom RX300, 39" DO, 53" Midi, Pelican 1650, 1560, Thinktank HD
nightcat Goldmember 4,533 posts Likes: 28 Joined Aug 2008 More info | Jul 29, 2013 14:05 | #4 After trying both, I got the 100mm. I preferred the slightly longer length along with nicer bokeh and less CA when used wide open.
Jul 29, 2013 15:24 | #5 85 gets my vote, not because I think it'll be better than the 100, but because the focal length is more different from the 135.
T2i4me Goldmember 2,906 posts Likes: 7 Joined Jun 2011 Location: Surf City, CA More info | Jul 29, 2013 17:32 | #6 Have not used the 100mm but I love my 85mm on my FF and crop body, very versatile either way. -- Eric --
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Jul 29, 2013 18:10 | #7 100x1.3 = 130mm which is roughly the classic 135mm portrait length. Taylor
Jul 30, 2013 04:13 | #8 Nightdiver13 wrote in post #16163696 Both would be fine. There is no generally preferable length, only what is preferable to you. If your plan is to get the 135, I'd get the 85 since you'd be more likely to keep it once you've purchased the 135. +1 Chris Marriott Photography
jimewall Goldmember 1,871 posts Likes: 11 Joined May 2008 Location: Cleveland, Ohio More info | Jul 30, 2013 07:34 | #9 tkbslc wrote in post #16164608 100x1.3 = 130mm which is roughly the classic 135mm portrait length. 85 x 1.3 = 110mm which is pretty close to the 100/105mm portrait length. I like a little wider, so I'd probably go 85mm. When it's a coin toss I generally buy the one I can find cheaper and that's probably the 85mm, too. This! Thanks for Reading & Good Luck - Jim
k-lo Goldmember 1,316 posts Likes: 1 Joined Jan 2010 Location: Lost in SN's Canon vs Nikon Thread More info | Jul 30, 2013 15:38 | #10 as others have stated: 85 -=Karlo=- 1D III, 5D Mark II, 17-40 4 L, 35 1.4 L 24-70 2.8 L, 135mm 2.0 L, 85mm 1.2 L II, 300mm f 2.8 L, 580EX II, and a crapload of Elinchrom Gear
| Latest registered member is MWCarlsson 1005 guests, 184 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
