How do the autofocus on these two compare?
I am planning to replace my 20d with the 6d....
kram obvious its pointless 2,612 posts Likes: 3 Joined Feb 2005 More info | Jul 31, 2013 04:12 | #1 How do the autofocus on these two compare? Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
Jul 31, 2013 05:46 | #2 Im petty sure that the AF on the 6D will be far superior to the AF on the 20D. 5D II | 40D | 350D | Canon EF 50mm f/1.8 | Canon EF-S 17-85mm f/4.0-5.6 IS USM | EF 35mm f/1.4L
Naito Member 172 posts Likes: 8 Joined Oct 2008 Location: Toronto More info | Jul 31, 2013 07:37 | #3 Not even remotely comparable, 6d trumps 20d in accuracy, speed, sensitivity. 20d is what, 10 years old now?? Did you really expect otherwise? Carl
jnadz Senior Member 279 posts Joined Feb 2012 More info | Jul 31, 2013 07:41 | #4 Yes accuracy would be roughly the same as reliability. Precision is different. So maybe he meant to say the precision of both will be about the same but the accuracy may differ slightly... Whether or not this statement is true, I'm not sure, but I would think the 6D's focus system would be superior. When canon wants to slightly cripple one aspect of a camera (like the focus on the 6D) so as not to cannibalize other cameras (5DIII), they tend to use a similar system to one that's already in place on either a lower line of camera or a system that's 1-2 years old... Since the 20D is much older than that, my guess is that, just based on the progression of technology alone, the 6D is better 5D Mark III | SL1 | EOS-M | S100
TeamSpeed 01010100 01010011 More info | Jul 31, 2013 07:42 | #5 Naito wrote in post #16169150 Not even remotely comparable, 6d trumps 20d in accuracy, speed, sensitivity. 20d is what, 10 years old now?? Did you really expect otherwise? ![]() # of years between cameras may not always tell the complete story. There were 4-5 years between the 5D and 5D2, however no difference really in AF. It really depends on the type of AF sensors employed, #, algorithmic changes, etc. Past Equipment | My Personal Gallery
Jul 31, 2013 07:43 | #6 Just wanted to be doubly sure Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
TeamSpeed 01010100 01010011 More info | Jul 31, 2013 07:47 | #7 You will be fine with the 6D AF, and you will undoubtedly love the images. Your 20D will be made obsolete, because you won't need the APS-C factor. If you crop the 6D images down to a 1.6 view, you will end up with the same resolution roughly as your 20D, same DOF, etc. Past Equipment | My Personal Gallery
Nemofoto Junior Member 21 posts Joined Jul 2013 More info | Jul 31, 2013 08:49 | #8 Hello,
Jul 31, 2013 08:52 | #9 Nemofoto wrote in post #16169334 Hello, I am a brand new "forumer" while I have been visiting this website for a long time as I find it really interesting. Excuse my "french", or in this case my english as I am french and I don't speak english in the same way as my mother tongue. I have a 6d,and I had before a 5dII. What I can say is that the 6d has an amazing AF system. It is working perfectly even if in some extreme cases the outer points work hardlier than the center point. The 6d is a great machine. It is perfectly built and its size and weight are just perfect. I com from a 5dII and i love my 6d much more than the 5dII. I had a 40d before and i have the same feeling as this older body in term of size, weight and reactivity. Moreover, it has new features very usefull ad funny. A must have! Welcome to the forum. Be sure to post some photos when you get a chance flickr
TeamSpeed 01010100 01010011 More info | Jul 31, 2013 09:18 | #10 Nemofoto wrote in post #16169334 Hello, I am a brand new "forumer" while I have been visiting this website for a long time as I find it really interesting. Excuse my "french", or in this case my english as I am french and I don't speak english in the same way as my mother tongue. I have a 6d,and I had before a 5dII. What I can say is that the 6d has an amazing AF system. It is working perfectly even if in some extreme cases the outer points work hardlier than the center point. The 6d is a great machine. It is perfectly built and its size and weight are just perfect. I com from a 5dII and i love my 6d much more than the 5dII. I had a 40d before and i have the same feeling as this older body in term of size, weight and reactivity. Moreover, it has new features very usefull ad funny. A must have! I understood you perfectly! I expect that the 20D, 5D, and 5D2 all had very similar AF systems, as there were too many changes between those particular models and generations. Canon really started to work on AF performance on the 7D and subsequent bodies, and now we have a great 5D3 FF sports-capable body, and the 6D is improved, etc. Canon is starting to kick things into gear over the past few years! Past Equipment | My Personal Gallery
ElectronGuru Senior Member 427 posts Joined Apr 2009 Location: Oregon More info | Jul 31, 2013 10:58 | #11 I went from the 20D to the 6D, with a few years in the middle on a 7D. One of my reasons for choosing the 6D was to get back to the simplicity I had with the 20D. For my slow careful work (main use), the 7D was overkill-complicated. "Light is the paint, lenses are brush, sensors are the canvas"
EverydayGetaway Cream of the Crop More info | Jul 31, 2013 11:27 | #12 kram wrote in post #16169165 Just wanted to be doubly sure ![]() It will be my first trial at a full frame and while I don't expect the af to match the 7d, it has to at least beat the 20d.... A lot of users who add a 6D to the stable end up neglecting their 7D, so don't write it off yet Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
Nemofoto Junior Member 21 posts Joined Jul 2013 More info | Aug 01, 2013 03:13 | #13 TeamSpeed wrote in post #16169419 I understood you perfectly! I expect that the 20D, 5D, and 5D2 all had very similar AF systems, as there were too many changes between those particular models and generations. Canon really started to work on AF performance on the 7D and subsequent bodies, and now we have a great 5D3 FF sports-capable body, and the 6D is improved, etc. Canon is starting to kick things into gear over the past few years! Welcome to POTN, we look forward to samples shots in the 6D photo thread: https://photography-on-the.net …/showthread.php?t=1252637 Thanks Jaomul and TeamSpeed, I am happy to notice that what I said is undestandable
| Latest registered member is Marcsaa 495 guests, 157 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
