Thread started 31 Jul 2013 (Wednesday) 04:51
Bullet-Time Photography
Eks
Jul 31, 2013 04:51 |  #1
Has anyone tried doing this? What softwares needed to trigger 30 cameras all at the same time? Are there any delays in triggering per cam? What software are you using to covert the photos to mpg file.
Thanks in advance.
Canon 30d with vertical grip
Ef 24-70 f/2.8L
Ef 70-200 IS f/2.8L
Ef 50mm f/1.4
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 31, 2013 08:06 |  #2
Without better info from you, the easiest way would be to do it in a dark room, put the cameras all on time exposure, & use a sound trigger to trip a strobe.
Harold Edgerton (external link) was stopping time decades ago with specialized cameras and lighting.
Simple strobe and sound trigger setup, (external link)
mORE: http://www.hiviz.com/t​ools/triggers/triggers​2.htm (external link)
high speed camera. (external link)
BobFranks
Gallery: 25 photos
Aug 01, 2013 19:00 |  #3
Is this (external link) what you are talking about?
You might be able to contact them on how they do it.
MM (external link)
DC ­ Fan
Aug 02, 2013 09:16 |  #4
Eks wrote in post #16168987 (external link)
Thanks in advance.
Breeze Systems has offered suitable software (external link) for several years.
Eks
Aug 05, 2013 03:10 |  #5
Hi sorry for late replies. Anyway i've a project that needs bullet-time effect. They wanted this effect on their event. After taking the shots it will be converted to video and send through Bluetooth to the guests.
Just wondering how do i trigger say 30 cameras, and if im going to use USB cable wouldn't be any delay in capturing the subject from each camera? What the fastest software do i use to covert all files to video?
Thanks in advance.
Ef 24-70 f/2.8L
Ef 70-200 IS f/2.8L
Ef 50mm f/1.4
Eks
Aug 05, 2013 03:22 |  #6
PhotosGuy wrote in post #16169224 (external link)
Thanks for the reply. Can it be triggered simultaneously at the same time without the sound trigger? As it will be used in an event. There will be lots of noise.
Ef 24-70 f/2.8L
Ef 70-200 IS f/2.8L
Ef 50mm f/1.4
Eks
Aug 05, 2013 03:25 |  #7
DC Fan wrote in post #16175172 (external link)
been checking this out. Mailed them also but they said i need a "relay" to fix the delay of each cameras. The relay thing is so complicated as i don't know anyone who can program the relay switch and master trigger.
Ef 24-70 f/2.8L
Ef 70-200 IS f/2.8L
Ef 50mm f/1.4
pwm2
"Sorry for being a noob"
Aug 05, 2013 03:39 |  #8
USB means you need to communicate with each camera - not good since it takes time.
Best option is to use cameras that takes a remote control - use the RC input to trig them.
Can be done with older cameras that uses IR, and can be done with all that have a traditional wire input.
If using cameras with IR remote input, then it takes a bit of electronics skill - basically a IR-sensitive photo transistor, a driver transistor and a number of IR LED and resistors - this allows you to tape an LED on each camera you want to control.
Edit: And you want all cameras to be same model, to make sure there aren't any significant differences in shutter lag. And same model makes it easier to make sure all cameras has the same configuration.
Eks
Aug 05, 2013 03:54 |  #9
Can pocket wizard do the trick?
Ef 24-70 f/2.8L
Ef 70-200 IS f/2.8L
Ef 50mm f/1.4
pwm2
Aug 05, 2013 03:59 |  #10
Eks wrote in post #16182137 (external link)
But a question then would be to have 30 receivers or splice cable to connect to the 30 cameras. Anything that activates the trig input on the camera can be used - as long as there are no random delays affecting different cameras differently.
Eks
Aug 05, 2013 04:02 |  #11
Thanks for the help.
Ef 24-70 f/2.8L
Ef 70-200 IS f/2.8L
Ef 50mm f/1.4
3,389 views & 0 likes for this thread, 5 members have posted to it.
716 guests, 120 members online
