There are a few reasons to use focus stacking for landscapes. Better iq when shooting stopped down is one reason. If your printing your pictures big I'm sure the stacking improves iq, but probably not so much if your just posting on the web.
Needing a DOF that exceeds what you can get with your desired settings is the big reason it's used though. The "with your desired settings" part is key.
Say your shooting some wildflowers and there is a slight breeze. F/16 may give you your DOF, but you you have a polarizer on which is sucking two stops of light, you bumped your ISO up a bit (or maybe you don't want to bump it up), and you need a relatively long shutter speed to get your desired exposure. Lets say the shutter speed came out to be 1/30 second. The problem is that 1/30 sec is long enough that the breeze can blow around the flowers quite a bit during the exposure. One solution would be to focus stack; opening up by two stops will allow you to use a 1/120 sec exposure which may be fast enough to freeze the blowing flowers.
If your shooting seascapes you may run into a similar situation where you need sufficient DOF, but also need to use an exact shutter speed to capture the perfect ammount of blur in the wave motion. Focus stacking could be a solution in this scenario as well.
The number of shots needed and where to focus is different for every image. There is deffinately a learning curve for focus stacking, but its not a steep curve at all.
